15 GT Oil/Transmission Cooling
4,015
1,954
Perfect. At this point, thinking a 660/610 combo for oil/tranny cooling mounted in the upper grill to an Improved Racing thermostatic filter mount into a Canton a remote adapter w/ drain back. Mounting and routing everything is going to be a challenge with the catch can and h/e pump w/ -20 hose and fittings taking up a lot of room in the engine bay and wheel well but I’ve got time to figure it out. Thanks for the help!
Boardkat, I mounted the oil filter behind the left front wheel splash shield on the frame rail tab. Gives some room to route lines to and from the cooler.
boardkat
CAMtard
131
179
Lake Oswego, OR
Yeah, I saw that picture - unfortunately, I don't have the room to fit a remote filter adapter there :(
Going to try and mount it in the engine bay instead; should be able to route the lines where the coolant feed to the OEM sandwich is (which I'll be removing), and mount the filter upside down for easy access (FRPP FL820 has an anti-drainback valve iirc so should be good to go):
