Boss 302 10's All Motor
Finally broke the 10 sec barrier. Simple bolt-ons as described in the Timeslip thread. True testament on the capability of the Boss engine.
Two weeks ago ran a best of 11.11 @ 123.75 with a 1.65 60 foot on ET Street Bias Ply's
Time to go for it... ;D
Switched to ET Drags 28 x 9 x 15 plus E85.
Car weight: 3760 w driver
Track details:
Temp: 55
DA: (350)
Launch RPM: 5500 (CJ two step)
Video:
http://www.youtube.com/watch?v=cRn5g9rETgU
Thanks
Its all in the details..
BTW, CJ Grille for sale on Ebay:
http://www.ebay.com/itm/2010-COBRA-JET-COBRAJET-FORD-RACING-FACTORY-GRILL-NEW-BOX-/321280511931?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4acdcf8fbb
302 Hi Pro
2,009
441
Southeast
Davsta:
Nice, real nice run and congrats on breaking in to the 10's. Like your hard launch signature photo with the left front wheel off the ground. Good luck this season.
302 Hi Pro
7,551
5,283
davsta said:
Thanks
I bought it.
racered302 said:
Whats a cj 2 step?
Rev limiter built into the tune and adjusted via custom tune options in the handheld. Set the desired launch RPM, once you have staged, hold the gas pedal to the floor. Release the clutch and the limiter is no longer active. Allows for a clean launch based on your suspension setup. CJ cars have this feature enabled by default.
seca954 said:
Your only "bolt ons" are E85 and slicks?
Car's progression is detailed in the "time slip" thread. Actual mods below:
Naturally Aspirated
MT82 w MGW Shifter
M\T ET Drags 28 x 9
3.90 gears
Kooks headers X pipe
GT500 Mufflers
Steeda CAI
Boss IM port cleanup
E85
47 LB Injectors
3760 LBS w Driver
TMSBOSS said:
I bought it.
Congrats, really improves airflow especially into the factory cold air ducting.
Naturally Aspirated
MT82 w MGW Shifter
M\T ET Drags 28 x 9
3.90 gears
GT500 Mufflers
Steeda CAI
E85
47 LB Injectors
3760 LBS w Driver
who did the Boss IM port cleanup for you?
seca954 said:
Are you running the stock axels and torsion rearend still?
Stock axles. Shelved Torsen and replaced with a locker.
Hand sanded over the weekend. Smoothed ports around the injector bosses. Also cleanup any runner misalignment due to molding process.
130
Naturally Aspirated
MT82 w MGW Shifter
M\T ET Drags 28 x 9
3.90 gears
GT500 Mufflers
Steeda CAI
E85
47 LB Injectors
3760 LBS w Driver
Tune?
Catted or OR x-pipe?
Any suspension mods, eg LGA, UCA or shocks?
Rich_S said:
Tune?
Tuned via Tuners Inc (Tony Gonyon). Close Colleagues with Shaun\AED. Also recently switched to HP Tuners software.
OR X Pipe
Metco upper and lowers in the rear. Factory shocks\springs etc. No front suspension mods other than CHE radiator brace. Factory rotors etc. Although looking at the Girodisc rotors +Battery relo via Blowfish & LS rear seat delete.
Latest update is that I got lucky and found a Factory NA CJ intake tube via Mike at Diversified Products in Michigan. Mike in turn set me up with Jason Antko and Patrick Lee at Watson Racing and they built a custom heat shied as the NA cars did not come pre-equipped. Once I get the setup installed, I will post photos.
237
Naturally Aspirated
MT82 w MGW Shifter
M\T ET Drags 28 x 9
3.90 gears
GT500 Mufflers
Steeda CAI
E85
47 LB Injectors
3760 LBS w Driver
Congrats bro !! , this looks absolutly amazing ..
What headers size dd u choose ? Did u change the over axle pipes ?
Can u explain whats the boss im port cleanup ? I would appreciate it if u can explain in simple english if u dont mind.
Keep it up, its amazing !!
