KNS Brakes
Supporting Vendor
292
20
Cary NC
We have a variety of single piece and two-piece Brake Rotors in stock. Below is a full list of our current selection.
DBA T2 Street Series Slotted Rotor
DBAs T2 Street Series is an entry level performance rotor, offering improved braking straight out of the box. Featuring DBAs patented pillar vane design and bi-symmetrical slot design, T2 is a strong, durable brake rotor that provides an attractive, aggressive appearance.
- Patented pillar vane venting increases heat dissipation
- Slotted friction surface increases pad bite and minimizes glazing
DBA T3 ClubSpec 4000 Series Slotted Rotor
DBA's T3 4000 series is a mid-range performance rotor, offering increased durability under hard braking conditions.
- XG150 High Carbon Alloyed Iron increases thermal capacity of the rotor
- Proprietary TSP heat treament process strengthens iron for resistance to cracking and warping
- Thermo-Graphic paint markings for effective heat monitoring
DBA T3 ClubSpec 5000 Series Two-Piece Slotted Brake Rotor
DBAs T3 5000 series is a top-range performance brake rotor. These rotors are a direct replacement for your factory disc brakes and replacement rings are available.
- 2-piece design allows the center hat and the ring to cool at different rates reducing thermal stress
AP Racing HD J-Hook Two-Piece Endurance Rotors
AP Racing's Heavy Duty Two Piece J Hook Discs improve brake performance and efficiency.
- Two piece 'floating' design allows even outer ring expansion
- Outer ring is isolated from hub for less heat transfer
- Curved vane design increases cooling
- Patented J-hook slot for increased bite and less pad glazing
- Engineered iron alloys are more efficient and consistent
Girodisc 2-Piece Floating Rotors
The Girodisc 2 piece rotor system is a direct replacement for the OEM brake disc and unless noted no modifications are necessary. The disc will bolt directly to the car and work perfectly with OEM calipers.
- 2 piece floating are lighter than OEM 1 piece rotors reducing unsprung and rotating weight
- Floating design allows for better performance under high heat conditions
- Curved vane rotor rings are more efficient at removing brake heat.
DBA T3 Clubspec 5000 Series Slotted Rotor Replacement - Ring Only
DBA T3 5000 Series Replacement Rotor Slotted - Ring Only
- Replacement ring for DBA 2-piece rotors
- Hardware is included
Girodisc 2-Piece Rotor Rings
Girodisc Slotted Replacement Rotor Ring - Ring Only
- Direct replacement for your Girodisc rotor assemblies
StopTech Cryo-Stop Slotted Sport Rotor
StopTech Cryo-Stop Slotted Sport Rotors are produced from high quality Centric Parts castings and finished in a durable black e-coating for corrosion resistance. StopTech Cryo-Stop Slotted Sport Rotors look great behind custom wheels and improve brake pad performance.
StopTech Cryo-Stop Drilled Sport Rotor
StopTech Cryo-Stop Drilled Sport Rotors are produced from high quality Centric Parts castings and finished in a durable black e-coating for corrosion resistance. StopTech Cryo-Stop Drilled Sport Rotors look great behind custom wheels and improve brake pad performance.
StopTech Slotted Sport Rotor
StopTech Slotted Sport Rotors are produced from high quality Centric Parts castings and finished in a durable black e-coating for corrosion resistance. StopTech Slotted Sport Rotors look great behind custom wheels and improve brake pad performance.
Centric Premium High Carbon Brake Rotor
Centric Premium High Carbon Brake Rotors contain an advanced metallurgy that greatly reduces the possibility of pad squeal especially with higher friction brake pad compounds.
Not all products are available for all models. Please use the car selector on our website to check stock. Thank you for your business.
