Enkei PF01 Sale! CorteX Custom Offset +47MM
Ok TMO members here's your chance to get the 18x10.5" Enkei PF01 wheels with the custom offset from CorteX with a 10% discount. These are in limited supply. When purchasing use the discount code below to get your discount. Don't wait as this scary deal disappears after Halloween.
http://cortexracing.com/product/enk...performance-light-weight-wheel-18-x10-5-47mm/
SKU: ENK-460-8105-6547BK
PF01 18x10.5 +47mm in Black Only
Price $385 each
TMO discount code: BMO-ENKEI-OCT15
Expires 10/31/15 at 11:59pm
These wheels looks great and save weight.
CorteX teamed up with Enkei to bring you a wheel that not only looks great, but fits your 2005+ Mustang perfectly. What's even better is if you also have the CorteX Xtreme-Grip suspension with the optional large tire fitment struts you can run the 18 x 10.5 +47 mm size on all 4 corners. Yes, this opens up the door to fit 305-315mm wide tires on the front of you Mustang without any overhang. They don't call it our setup Xtreme-Grip for no reason!
If you have OEM struts and camber plates with at least -2.0 degrees of camber you can also order our optional large wheel fitment kit to install the wheels without interference. The fitment kit includes Ford hubs with 3 inch ARP studs, a set of 3/8 inch wheels spacers, and also a set of 10 open ended lug nuts.
A set of 20 Gorilla Black Chrome open lug nuts are optional.
*** 18 x 10.5 +47mm size is only available in black at this time. ***
@Gray Ghost GT this is an old thread. In the past couple of years there have been a few reported 18x9.5" Enkei PF01's crack their spokes. While we haven't seen any disastrous results yet I'd look elsewhere. Like the Apex 18x10 or 18x11.
Yikes. For clarification, from what you've seen reported have the cracks been particular to just the 18x9.5's and NOT the 10.5's? (That's what I have)
Thanks
