Favorite way to compress a McPherson strut?
Duane Black
Curbs go brrrppp
581
415
Durham, NC
So what's your favorite way to handle a real-live jack in the box?
I've usually rented the little shiznit tool from the parts store.... I was checking into just buying one for myself and I stumbles across this little joy.
https://www.harborfreight.com/single-action-strut-spring-compressor-43753.html
It's twice as much, but does it make the job of compressing a spring twice as easy? I can also buy the standard parts store tool. But, I'm tired of renting the tool not knowing what's going to be missing, which bolt for it will be stripped, etc., so I'd like to invest in my own tool for the future.
7,556
5,291
I have a spring compressor set for coils that attack to the outside and work fine, they also fit inside conventional coils.
I am Not a big fan of Harbor freight quality. They may work a few times but are not made of the long haul.
I bought mine years ago. They look similar to these but can be used internal or external to the spring depending on the application.
https://www.amazon.com/OEMTOOLS-Mac...sprefix=coil+spring+compressor,aps,273&sr=8-6
675
253
I've used the usual crummy 'hook and screw' type numerous times on a few vehicles and it works 100% fine. It's not as trick as the piece you've linked but it works.
1,249
1,243
In the V6L
I have an OTC 6494, which looks the same as the HF unit, except it costs three times as much. I used the hook and screw ones for years, and got tired of fighting with them. The OTC is much easier to use and way safer.
xr7
TMO Addict?
719
841
Minnesota
I use the same set as TMSBOSS, only I use 2 sets on the spring, I feel a lot safer with 4 bolts caging the spring rather than just two bolts. Less chance for the spring to slip out and do some serious damage, lots of stored energy. You can reposition a pair of bolts while the other pair holds the spring. Harbor Freight, Ebay, Northern Tool all selling the same tool.
2,203
1,067
Bay Area
FWIW- I only buy HF tools to break them. I consider that my disposable tool store. If you're doing one and done job then do it and don't expect much from the HF tool afterwards. If you plan on using them on a regular basis buy something that is known to last. But I must say, I did buy a set of impact sockets from HF almost 20 years ago. They are still working just as good as my snap on and craftsman stuff so I did get lucky there
Agreed, most of their stuff is such poor "made somewhere else" quality. I had a 3/8th drive ext just twist and come apart with maybe 10ftlbs. Checked it at work, poor material and heat treat surface was hard middle was "O" condition soft.
8,496
8,493
My favorite way to compress a McPerson strut is to.......................let someone else do it.
Sorry ,could not resist and pretty sure Tyme, TMS, 12CoBoss, Auteaux and others will agree ( on my favorite way to do lots of work ), ha?!
I have the HFT compressor above. It's HEAVY and bit cumbersome but it does the job. If I had to do it again I would get the two-piece set TymeSlayer uses.
