Price: $20,500
VIN: 1ZVBP8CF3C5278768
Text: (719) 440-8952
E-Mail: [email protected]
It's time to let her go. I purchased it with 8,400-ish miles on the odometer. I just don't drive it and I am out of garage space. Never 1/4 mile raced. Fluids changed religiously. Engine is 100% stock and accident free. Color is Kona blue. The rear spoiler and hood are flat black. Carfax and parts invoices available.
https://cosprings.craigslist.org/cto/d/colorado-springs-2012-ford-mustang-gt/7028064927.html
Engine:
• Steeda Cold Air Intake - Manual (11-14 GT)
• JLT Black Oil Separator - Passenger Side (11-17 GT; 12-13 BOSS)
Transmission/Clutch:
• MGW Race Spec Short Throw Shifter (GT / BOSS 302)
• MGW Gripper Shift Knob, 6 Speed (Reverse Upper Left) M12 x 1.25
• Steeda S197 Mustang Clutch Spring Assist (11-14)
• Steeda Mustang Stainless Braided Clutch Line (05-14)
• Steeda MT-82 Transmission Mount Bushing Insert (11-16)
• Exedy Mach 500 Stage 3 Organic Clutch Kit w/ Hydraulic Throw-out Bearing - 23 Spline (11-14 GT)
• McLeod Lightened Steel Flywheel - 8 Bolt (96-04 Cobra, Mach 1; 99-Mid 01 GT; 11-14 GT, BOSS 302)
Suspension (Front):
• Motion Control Suspension TT1 Single Adjustable Dampers (MCS-S197-TT1 (non-remote) for Ford S197 Mustang (pin-eye rear) MCS-S197-TT1
• Springs: HS-60-7-550 Hyperco Coilover Spring, 60mm x 7" x 550 #/in
• Camber Plates: A1-2001-02 Vorshlag S197 Mustang Revised Aluminum Camber/Caster Plates & 60mm Perches (pair) *Built for MCS strut profile
• Sway Bar: Ford Racing Adjustable Sway bar Kit (M-5490-A)
• Whiteline Front Heavy Duty Adjustable End Links, For MCS (KLC179)
• Maximum Motorsports Bumpsteer kit, 2005-2014 Mustang, tapered-stud style
Suspension (Rear):
• HS-2.25-8-250 Hyperco Coilover Spring, 2.25" x 8" x 250 #/in
• Vorshlag HD Rear Shock Mounts
• Whiteline Watts Link Assembly - 2005 - 2014 Ford Mustang
• Whiteline Rear Sway Bar - 27mm Heavy Duty Blade Adjustable 2005-2014 Mustang
• Maximum Motorsports Relocation Brackets for RLCA, 2005-2014
• Maximum Motorsports Rear Lower Control Arms (05-14 All)
• Steeda Adjustable Mustang Upper Control Arm - Poly End (11-14)
• Steeda Mustang Upper Chassis Mount for 3rd Link (11-14)
Wheels/Tires:
• Current wheels are SVT type from a 2010 GT500; the stock wheels no longer fit over the installed Brembos
• Ford Performance Front Hub Kit w/ 3 in. ARP Studs (05-14 All)
• 3" extended ARP wheel studs (Rear)
Differential:
• Ford Racing Boss 302 Torsen Differential - 31 Spline 8.8 in
• Ford Racing 3.73 Gears (10-14 GT)
Brakes:
• Vorshlag: S197 Mustang 14" Brembo Front Brake Upgrade Kit
• Vorshlag: S197 Mustang 13.8" GT500 Rear Brake Upgrade Kit
• Vorshlag S197 SS Braided Brake Line Kit [91-20SB]
• Shelby Isolation Clutch Remote Reservoir Kit (10-14 All)
Body:
• Tiger Racing Louvered Fiberglass Hood 2005-2014 Mustang (Stock hood comes with the car)
Engine:
Suspension (Front):
Suspension (Rear):
Wheels/Tires:
Differential:
Brakes:
Body:
