JRi rear coilover install
Does anyone know the torque value for the JRi rear coilover bolts? I think the ones for the KONIs are different and they are the only ones I can find on their website. When I was torquing down the bolts the spacer split.62330D38-976F-4E2B-8A5F-A9A4DA1A2111.jpeg3A118C76-6C95-4237-871B-FECBF5FD4B2C.jpegDECC47A8-856A-4161-87A2-08A2F7E643EE.jpeg199304FC-7163-4C63-BD96-3825659BCF54.jpeg
I used the spacer from the old coil overs and everything bolted up as it should. The new spacer’s hole diameter is too large, slid over the internal joint and cracked. I wish I would have checked the top but it torqued down fine. I would recommend checking this part if you have the same set.1A710456-52D9-4EAE-BB88-566FA3039728.jpeg902A91F7-87B2-4E81-8463-5AB2E2D7E057.jpeg291E5C95-F8BD-4BCE-B0EA-91023CAEDB52.jpeg29FDF718-0721-474F-BCBC-DD165489327C.jpegF49AEECC-61BF-4819-9B62-2F5E61F9DC5C.jpeg
