Maximum Motorsports new K member
Do they have a new one? I am only seeing the same one on the website?
It’s relatively new. They (MM) have done K members for older Mustangs but not the S197 until recently. There isn’t much out there as far as installation and use experience.
I've been using it for 3-4 years now and no issue so far. Only the K member, not the radiator support or swaybar bracket. It wasn't available when I bought it.
I don't remember the different feeling compared to stock, it's been swapped a while ago. But it does make working in the engine area and front suspension much easier as it clears a lot of space.
Couple things to keep in mind :
-Won't work with extended ball joint like the Ford Racing Howe unless you convert the bumpsteer to a bolt through which means drilling the spindle. MM sells a kit for that (MMTR-5).
-I'm using solid motor mount (Watson) and had to enlarge the holes that bolt o the K member. Shouldn't be a problem if you're using the stock one as the play in the bushing would compensate for the misalignment.
-I had to shim the driver FLCA rear mount. Wasn't perfectly aligned and would put tension on the bushing and wear it prematurely. I have solid delrin bushing for the FLCA, also shouldn't be a problem if you're using stock bushing.
Great - thanks for the feedback. I ordered the radiator support and swaybar brackets so we’ll see how that all works with my Whiteline bar. I’m using urethane motor mounts too so appreciate the heads up on fitment. I’ll report back when she’s all bolted up.
It’s been around a few years. Works alright from those that use it. Many race classes have a heavy handed weight/power penalty for use so not a lot of them seen in club racing
Gotcha on the rules issue. Didn’t really consider that - guess I’ll have to do an all out build now[emoji6]
