I put one in last weekend after getting fed up with missing even with a Barton with 2 post bracket. Driveway install with a bit too much up top/down under for a 55 y/o guy but couldn't be happier with the results. Rock solid every shift now. Hardest part for me was snaking my arm through the shifter opening to get the tapered bolt holding the knuckle rod linkage to the input shaft rod. Requires slight pressure forward to relieve the tension on the pin and not easily done 1 handed but eventually got it. Worth every penny!M91196 said:Great product.
