Questions for the DIY alignment gurus
Norm Peterson
Corner Barstool Sitter
939
712
a few miles east of Philly
IF GROUND IS NOT LEVEL: Before checking camber remove AccuLevel™ and place on ground parallel to axle centerline. If it does not read 0.0° push “ZERO”. Replace AccuLevel™ in gauge and proceed as above. This must be done on each side of the car and will compensate for non-level ground. Push “ZERO” again to go back to normal (absolute) operation.
This is what I'm using for an instruction. Taken right from the instructions. If this isn't correct, why did they put this in the instructions?
Based on your reply, you are saying the instructions as stated above aren't worth the paper they are printed on.
Non-level is not exactly the same thing as "flat with a slope". Localized out-of-flatness would basically tell lies to the AccuLevel, and different setup areas would tell different lies.
I'm afraid I don't know much about the AccuLevel, including things like how fussy or easily repeatable its setup procedure might be. Things like that remove. zero, and replace sequence in particular. How much camber "shift" have you noticed, and how do those changes compare to the scale's 1/4° resolution?
As far as I know, camber is the angle between the plane of the wheel and a line drawn perpendicular to the ground assuming that the ground is both flat and level. After all, the ultimate object of a performance camber alignment is to put the tire at whatever inclination relative to the contact patch plane proves to be optimal for maximum grip, or is desired in order to obtain a particular handling balance.
Inclination of the wheel plane relative to the chassis while driving is really just a consequence of suspension stiffness in ride and roll. Ford and other mfrs do tie alignment to the stock ride heights, but that's only a reference for putting factory-preferred camber (and camber gain, at least theoretically) where they designed their stock ride height car to have them.
Norm
6,394
8,275
This will always be my favorite way of measuring toe at the track..use 2 plates and this home made gauge, no remembering the measurements and you can visually see the difference.
hardware store parts
drill a hole for the screw and weld the nut to the big tube
Slide the rod into the tube
the completed toe gauge
