Strut tower opening enlarging
Die grinder. Mark it off with a sharpie and get busy.
I haven't done it myself but the jig they made for the s197 looks real nice. Using a hole saw seems like the way to go, the trick is just centering the bit. I've been pondering using a piece of wood to center the pilot bit (drill in the center of the hole saw).
Did you make the whole hole larger? Most of the race cars cut a slot so you can move the damper adjuster over further which is the cause for the limited adjustability. I’m traveling but do an internet search.
@blacksheep-1
The plan for me is to use the hole saw to increase the ability to adjust camber using Pedders camber plates which require a larger opening to adjust camber on the car or dropping the strut to adjust camber.6c19ef122ff91863ef79c1a69bc7a8ca.jpg
Sent from my SM-G960U using Tapatalk
7,554
5,288
Curious if any of the “Engineer Types” (Grant) can chime in on strength concerns.
Does cutting the larger hole weaken the structure of the tower more so than the elongation process?
Try to keep the answer under 2500 words and use small works for us knuckle draggers, please.:rolleyes:
It's a concern. Not a big one IMO in the two pics above.
I dunno what you mean. :D;)
In the S550 mount I don't see any problems opening up the hole with that saw and eliminating the two original notches.
This is about the limit of what I'd cut from the tower. Keeping the lip around the opening is a good thing. Could use some clean up.
Some seam welding a bit around the top plate to the tower wouldn't be a bad idea, but not needed.
The main thing to avoid are slots and sharp interior corners for the hole.
There is no adjusting camber on the car using these plates without opening up the tower in this way. Doing it the other way will not work due to the way the adjustment is done using the Allen headed screws.
