Strut tower opening enlarging
It's a concern. Not a big one IMO in the two pics above.
I dunno what you mean. :D;)
In the S550 mount I don't see any problems opening up the hole with that saw and eliminating the two original notches.
This is about the limit of what I'd cut from the tower. Keeping the lip around the opening is a good thing. Could use some clean up.
Some seam welding a bit around the top plate to the tower wouldn't be a bad idea, but not needed.
The main thing to avoid are slots and sharp interior corners for the hole.
boardkat
CAMtard
131
179
Lake Oswego, OR
I took some measurements and had a friend waterjet a template for me to use for opening them up with a hole saw on my ‘15. Main driver was similar, I wanted to be able to adjust camber without having to drop the strut.
Didn’t take any pics during the process but here’s what it looks like (I unbolted the strut and attached with nuts and bolts from underneath):
And here’s the outcome;
6,394
8,273
Cut baby cut, the hole will be elongated..I think Sal Molinare actually has a jig for this. I can't find a pic, but I know I have posted it up before. You basically mark what you need and die grind it out like Voodoo boss mentioned. You will cut through part of the "lip" but it won't matter.
Fair
Go Big or Go Home
Supporting Vendor
277
492
Plano, TX
We heard your questions about this task and responded with these fixture tools...
We had one of these we hand made 5+ years ago for the S197 chassis but now we have them for 6 different chassis, which we make with our CNC machines plus a little welding
Make this job a snap on either chassis... bolt this fixture in from underneath and then line up the hole saw on top. I've done this to 50+ customer cars and both of my S550. On the S550 a 2-3/4" or 3" hole saw works best.
Here are the steps on the S197. These have the same restriction - a tiny opening in the tower. Our 4 bolt fixture is bolted in from underneath then...
Line up the hole saw and go to town. We use a 2-1/2" or 2-3/4" hole saw on the S197.
This ST2 classed 2013 Mustang has been on track for several years with this setup.
S197 tool: https://vorshlag-store.com/collecti...roducts/s197-strut-tower-cutting-fixture-tool
S550 tool: https://vorshlag-store.com/collecti...roducts/s550-strut-tower-cutting-fixture-tool
Cheers,
I didn't know you were selling those tools. Nothing like having the right tool for the job.
6,550
8,202
If you make an aluminum template be sure to replace the center drill bit with a piece of 1/4" round bar so the drill bit doesn't wobble out the hole.
20842164_10155622027078535_1075687452685254661_n.jpg20953321_10155622027223535_6763041289942631815_n.jpg20882029_10155622027093535_2384188022184520198_n.jpg
captdistraction
GrumpyRacer
1,954
1,698
Phoenix, Az
I opened mine up the PWC way, and switched my plates to (modified) vorshlag plates so I could more easily do on-car adjustments (as I had the same style of plate that uses the socket cap screws to adjust). I'm just not a fan of those style plates in general. Used a angle grinder with a cutoff wheel for the big cuts, then dremel with various bits to clean it up. Beauty was a secondary concern in my application, it could be done far more cleanly.
