With the failures of the stock oil cooler it might make sense to remove it. Now that Mishimoto has a t-stat sandwich plate specifically for our cars this project just became a lot easier to build.
If you remove the stock oil cooler what size cooler is needed to properly cool the oil? Also what parts are needed? Obviously you need the stock GT hoses to replace the Boss oil cooler hoses, new hoses from the sandwich plate to the cooler, a cooler, a cooler mount and a sandwich plate. Anything else?
Note: I'll update this post with links to parts as they are presented.
Mike is making a cooler mount:
https://trackmustangsonline.com/threads/any-interest-in-oil-cooler-mount-brackets.7448/
Mishomoto t-stat sandwich plate:
http://www.mishimoto.com/rear-mount-thermostatic-sandwich-plate-m-22.html
Setrab Oil coolers:
http://www.improvedracing.com/setrab-oil-coolers/setrab-25-row-series-oil-cooler-p-193.html
http://www.improvedracing.com/setrab-oil-coolers/setrab-34-row-series-oil-cooler-p-235.html
GT radiator hoses:
Motorcraft KM-5052 or KM-5136
Short oil filter adapter spud:
Ford P/N AL3Z6890A
Oil hoses:
AN fittings:
Other Oil Cooler Installs:
https://trackmustangsonline.com/threads/my-diy-oil-cooler-install-a-few-pics.6652/
https://trackmustangsonline.com/thr...or-a-barely-tracked-2013-gt-update-yes.11832/
https://trackmustangsonline.com/index.php?topic=7215.0;topicseen
https://trackmustangsonline.com/index.php?topic=3175.msg51292#msg51292
https://trackmustangsonline.com/index.php?topic=6673.0
https://trackmustangsonline.com/threads/in-light-of-oil-cooler-leaks.6703/
Setrab Oil coolers:
GT radiator hoses:
Ford P/N AL3Z6890A
Oil hoses:
AN fittings:
