Camber bolts needed?
So I finaly got my front springs done ( FRPP T) springs, BMR LCA's and relo brackets and am taking it in for an alignment on Wednesday. Along with that, I'm getting them to instal the adjustable BMR UCA and mount as I couldn't get the bolt under the seat off with the tools I have. My question is will I need the camber bolts. How much - camber will they provide, and would it be beneficial to put them in for just street and highway driving. Will there be enough -camber to chew up the outsides of the tires? Also, what pinion angle would work the best for my setup with the one peice aluminum driveshaft I now have?
Thanks again for your opinions.
4,017
1,962
Lowering the front will give an increase in negative camber with the T springs on a Boss maybe .2 degree more than what you had stock. So the wear will move twards the inside shoulder but not much. I personally don't like camber bolts, if you want adjustable camber to allow more negative then go with camber/caster plates either from Maximum Motorsports or Vorschlag. They are both well tested and respected setups. Camber bolts are cheap but they don't hold adjustment well and if installed poorly can cause stress failure at the spindle upright due to movement at the base of the strut.
Just my $.02
+1, with Steve, I had camber bolts for a very short time and wasn't entirely thrilled with riding around with them installed. A smaller bolt with less torque than the stock bolt doesn't seem like the right way to go for adjustability. As for the pinion angle I believe -2 is usually what people say works best, however I would call the manufacturer of the DS and ask them what they recommend as each one is a little different I believe.
Just my $.02
Thank you Steve, I'll just leave the stock bolts in!
Thanks Brandon302, The instructions say -2 to -3 with the stock two peice. I would think that it would be safe in that range.
