Maximum Motorsports Road and Track Box
Remove this:
Install this:
End up with this:
I went with the XD Rear Lower Control Arms instead of what was in the package. From the measurements I took before the install it looks like the front is 1" lower and the rear is 2" lower.
Paul
1,281
Tulsa, OK
I was surprised that the springs were progressive, as well. I went to look at these springs when I was shopping for a new set but wanted linear rate.
Looks really nice 8)
898
544
Didn't you go with a set of H&R Race which are progressive too? I myself am trying to decide between the H&R Race and the MM springs.
Those will probably keep all the 'tender' coils in bind...so it should mostly function like a linear rate spring in the normal working range. The tender coils are there to have enough spring height so the spring doesn't fall out of the perches when the suspension fully unloads, and that it doesn't unload before running out of travel.
Looks great and looking forward to your review.
