2015 Mustang GT Vehicle Profile & Build Thread
N/A build focused on HPDE track sessions. Chasing lap times and looking pretty while doing it.
N/A Build Focused on Turning
Lap times
S550 Model
GT
Suspension:
- BMR Sway Bars
- BMR Sway Bar End links
- BMR Rear upper shock mounts v3 + brace in trunk
- Eibach Pro-Kit springs
- Ford Performance "Track" FR3 Shocks
- Steeda bump stops
- Steeda Bump Steer Kit
- Steeda Front Control Arms (Lateral and Tension Links w/ Bearings)
- Steeda Front Camber Plates
- Steeda strut tower brace
IRS upgrades:
- DSS 800hp Axles (Road Course Upgrade)
- Steeda Delrin Vertical Links
- Steeda rear upper camber links (v2)
- Steeda Diff Bushing inserts (first the Black ones, eventually switched to the red ones)
- BMR BK048 Delrin Cradle bushings
- BMR TR005 Toe-Links
- Ford racing toe-knuckle bushings
- BMR BK055 Rear Lower Control Arm Bearing Kit
Brakes:
- Steeda 2-piece rotors at all 4 corners
- G-LOC race pads F-R10, R-R8
- Steeda SS braided brake lines
- Motul 660 brake fluid
Close to stock power. About 460.
Engine
(rebuilt Jan 2020 by Holbrook racing after spun rod bearings on a road course)
- Diamond Pistons 11.5 to 1
- MANLEY Forged H-beam Rods
- Ported Heads
- CompCams NA Stage 2
- BEEHIVE VALVE SPRINGS
- CLEVITE bearings
- ARP bolts throughout the bottom end
- Moroso Aluminum Road Race Oil Pan (20572)
- JLT GT350 air intake
- GT350 Throttle Body (ported by AirFlowSolutions)
- GT350 Intake Manifold (ported by AirFlowSolutions)
- ATi balancer
- MMR Hurricane Oil Pump
- TSS Crankshaft Sprocket Gear
- MMR water pump pulley
- FRPP LU47 injectors
- Mishimoto Oil Cooler (but I use a filter relocation kit by MMR)
- nGauge tuner
- Lund tunes (93, E85)
- 200A Alternator
Visual mods:
- Matte black Emblems from UPR
- Tint: 50 windshield, 35 sides, 20 rear
- Blue Ford Racing engine Coil-Covers
Aero:
- Steeda front splitter + diffusers by Professional Awesome
- APR GT200 carbon Fiber wing
- MP Concepts 350 style hood with TracSpec center vent & Aerocatch hood latches
- Redline hood struts
- Front tow hook from ZL1addons.com
Wheel/Tires:
- Street Setup - HRE FF15 Tarmac Wheels w/ Nitto 555g2 tires 20x10 front - 285/30r20, 20x11 rear - 305/30r20
- Drag Setup - HRE FF15 rear 18x10.5 with Nitto NT05R 315/40r18 drag radials
- Track Setup - SQUARE 19x11 Forged NES track wheels with 305/30/19 Falken RT660 tires
- White shift Knob from CJponyparts
- GT350 steering Wheel
- MGW race spec shifter (standard handle, oem knob adapter)
Race. Break. Fix. Repeat. Hunting for lower bottom end power as it is a dog under 5000 RPMS
S550 Mustangs
TrackGT
More in S550 Mustangs
