2008 Mustang GT_46L Profile
HPDE/Track
2008 Mustang
GT_46L HPDE/Track -  (Street/Canyon Build)
Street/Canyon Build
S197 Model
GT 4.6L
Front:
MM C/C plates
MM K-member
MM trans cooler scoop
MM radiator core support
MM core support reinforcement braces
MM front sway bar
MM bumpsteer kit
MM adjustable end links
MM road & track springs
Bilstein front struts
Speedway clamp-on K-member tow hook
Ford Racing FR500S P/S cooler
Ford Racing GT500 front control arms
Ford Racing front hubs
StopTech STR-40 14” front big brake kit
Girodisc 14” front rotors
Girodisc street/strip brake pads
OP 20mm front wheel spacers
Voshlag front brake cooling deflectors
GT500 brake booster
GT500 master cylinder
Ford Racing clutch fluid line
CHE race torque links
Rear:
MM rear arm relocation brackets
MM HD rear lower arms
MM Panhard bar
Bilstein rear shocks
Roush rear upper arm
Trinity GT500 rear diff housing bushing
Girodisc 11.8” rear rotors
Performance friction rear brake pads
Ford OEM rear calipers
StopTech SS rear brake lines
ARP extended rear wheel studs
OP 20mm rear wheel spacers
Eaton truetrac
Ford Racing 3:73
Ford Racing finned diff cover
Joes differential vent tank
Ford 18mm rsb w/poly bushings, lateral locks
Voshlag rear tie downs
Wheels & Tires:
Street: OEM 18x8.5 et50 Bullitt wheels, Firestone Indy500 tires, 255/45/18
Serious street😆/Canyon: Team Dynamics 18x10 et45 wheels, Kumho Ecsta V730 tires, 275/35/18
Monster lug nuts & locks
Chassis:
KB jacking rails
KB chassis brace
Steeda trunk x-brace
Ford Racing cold air intake
Ford Racing 62mm throttle body
Ford Racing shorty headers
Ford Racing x-pipe
Ford Racing GT500 cooling fan
Ford Racing FR500S Radiator ducts
Ford Racing Boss 302 radiator
Moroso coolant reservoir
C&R P/S reservoir
JLT oil catch can
Trinity GT500 oil pan
Improved Racing oil filter & cooler adapters
Improved Racing remote oil filter mount
CSF oil cooler
Romac harmonic balancer
Borla XR1 race mufflers
SLP muffler deletes
91 Octane Dynotune by FTK
Drivetrain: OEM TR3650
Barton short shifter
ACT street clutch disc
ACT prolite flywheel
Ford Racing aluminum driveshaft
CE driveshaft loop
CDC front chin spoiler
CDC sequential taillight kit
MRT hood struts
Autometer gauges:
Oil pressure
Oil temperature
Water temperature
GT500 steering wheel
Circuit hero teardrop shift knob
3/8” Gas pedal spacers
1.5” Aluminum clutch pedal spacer
SRP pedal set
OEM seats w/Schroth quickfit harness
H3R 2.5lb Fire extinguisher & mount
Pioneer head unit
Coilovers
The car is built for street/weekend canyon run. Finished project.
Short circuit
More in S197 Mustangs
