- 334
- 352
I have a 2011 GT that, as usual, was leaking diff fluid out of the vent cap on the right side of the axle during track events. So I installed the finned Boss/FRPP diff cover that has the baffled vent on the top of the cover, plugged the original vent hole, and filled with 2.5 qts oil. All seemed good for a couple events but now fluid seems to be leaking out at the right side hub. The axle is dry and it's not leaking out of the vent. But this only is happening on track. It seems if the axle seal was bad, it would leak all the time. And if the new setup isn't venting properly, and the axle is getting too much pressure, it should leak from both sides, right? One weird thing, I have that "turkey baster" vent that Ford sells, - which I originally (and unsuccessfully) tried to use in the original vent location - installed on the top of the diff cover. Does that turkey baster restrict ventilation perhaps?
I'm stumped, any help appreciated. Thanks!
