- 6,394
- 8,275
It seems that the old stick axle cars liked a 2 psi split on the heavy end, the IRS cars seem to be heading towards the same psi all the way around. The big question always is and will be..what were your target hot pressures? The difference between 37 and 50 degrees (depending also on the track surface) is about 1 psi.
