► APEX | SM-10 Lightweight Track Wheels for Mustang
Discussion in 'APEX Race Parts' started by APEXRaceParts, Dec 26, 2018.
  1. APEXRaceParts
    APEXRaceParts Race Proven, Street Approved
    395
    505
    Jan 23, 2017
    Bay Area, CA
    [​IMG]
    Introducing the new APEX SM-10 for Mustang
    The new APEX SM-10 wheel for Mustangs combine a straight 10-spoke design with our “I-beam” milling technique to produce a lightweight wheel. The face profile provides unmatched big brake clearance while the new milling feature has increased strength while shedding weight, and it adds a visual feature typically only found on the most expensive race wheels available on the market today.
    Visit our website to order
    SM-10 Design Features
    [​IMG]
    1. Fit Matters
    These concave SM-10 wheels are designed specifically for your Mustang. The SM-10 provides chassis optimized fitments and proper load distribution. If you’re looking for a cost-effective lightweight 19” wheel, this is your answer.
    2. Face Profile
    All Mustang SM-10 wheels are built with a profile 2 - medium concavity face profile, as that yields optimum results with each of the wheel specifications.
    3. “I-Beam” Spokes
    The spokes of the SM-10 were designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. It’s expensive and avoided by almost every manufacturer, but affordable with volume. In each concavity profile of our SM-10 design, the I-beam spokes are carefully evaluated from structural aspects to ensure minimal weight, brake clearance, and remarkable strength.
    4. Beefier Lips
    By saving weight elsewhere, we’ve added extra material where it counts. We’re beefing up the barrel’s inner lip on the SM-10 to better handle the repetitive abuse seen on the track.
    5. Knurled Bead
    We’ve upgraded these wheels to include a knurled bead seat to reduce unwanted tire rotation. This added feature will help keep your balance stay truer throughout the life of the tire.
    6. Open Center
    Unlike the narrow lug recesses of most other wheels, the SM-10 wheel features a wide open hub center that easily accommodates oversized race lugs and beefy impact sockets. This allows for quick and easy wheel changes and prevents chips and scratches from tools.
    7. Center Caps
    We don't reuse one cap design for all of our wheels. Every SM-10 wheel is designed to work with factory center caps. You can easily replace APEX center caps with OEM S550 Mustang caps for a clean factory look. The SM-10 wheels will ship with our Gloss Black center cap that mimics the size and shape of a Mustang factory center cap.
    8. Hub Centric
    All APEX wheels are purpose-built for select vehicle applications, and centering rings are never required for any Mustang application. All 5x114.3mm bolt pattern wheels feature a direct-fit, 70.5mm center bore.
    9. Brake Clearance
    Spoke clearance is only half the problem. The barrel construction on a wheel also needs to be big enough to clear the sides of your caliper and rotor. Many aftermarket wheels that have aesthetic compromises in their design may work with smaller stock brakes, or smaller diameter big brake kits, but the larger kits will pose a major problem. Targeted at the serious performance-minded owner, 19” SM-10 wheels clear up to 15.5” diameter rotors and 6 piston calipers found on the GT350.
    10. Wheel Hardware
    The SM-10 Mustang wheel can be used with all OEM and aftermarket mounting hardware with a ball seat lug recess. Lug bolts, wheel locks, and stud conversion kits all work perfectly. The SM-10 wheel also accepts wheel spacers without issue. The shallow rear chamfer allows the wheel to remain hub centric even when 5mm flat spacers are used. The chamfer is deep enough to clear the chamfered lip found on some aftermarket spacers that would typically cause improper seating of the wheel and, therefore, wheel vibration.
    11. TPMS
    TPMS sensors, which monitor tire pressure, are one piece of technology that can't be compromised. All APEX wheels accept OEM and aftermarket equivalent Ford/HUF TPMS sensors, and any standard sized metal or rubber valve stem. Use the chart below to help select the correct TPMS for your vehicle.
    Designed For The Performance Enthusiast
    Light-weight
    Flow-forming allows for a significant reduction in rotational mass by reducing barrel weight. This manufacturing technique allows our wheels to be almost as light as a traditional forged wheel, but without the significant increase in price.
    Strength
    Track duty requires a wheel that can handle the punishment of high lateral G’s, hitting berms, and every once in a while, a small off-track excursion. Spoke and barrel design are a major factor in wheel strength. The flow-forming technique uses high-pressure disks/rollers to roll the wheel’s barrel into its final shape. This gives the barrel the same strength properties as a forged wheel since monoblock wheels go through a similar step to form their barrels. We design our spoke dimensions to help evenly distribute loads from the barrel to the center of the wheel. The lack of a front lip, and spokes directly connecting to the edge of the wheel, also add increased strength to the outer lip of the wheel.
    Chassis-Specific Fitments
    Stretched rubber, narrow tires, and fender rubbing are not elements to look for in a competitive wheel/tire setup. All of our wheels were designed with offsets that allow for proper fitment of extreme summer, and r-compound tires without the need for spacers or fender rolling. This means keeping the tire under the fender, and away from suspension components. Track oriented wheel widths are also important as they provide proper sidewall support under hard cornering. Too much rubber for a wheel results in excessive sidewall deflection, which translates into sloppy and delayed turning response.
    The APEX Standard
    [​IMG]
    1. Testing & Certifications
    Computer simulated stress tests are no match for real-world testing when designing a lightweight wheel that will see extreme loads. All APEX wheels are crush and load tested to exceed JWL standards and those results are independently tested and certified in Japan by the 3rd party government agency known as the VIA. Countless wheel companies falsely claim they are tested and certified by the VIA, and so they lack the certificates to prove it. We test and certify each and every design, diameter, width, and offset, separately.
    2. Always Flow Formed
    All APEX wheels, including the SM-10 wheel, are produced using the Flow-Forming technique. This process significantly reduces weight in the barrel, which has the greatest impact on rotational mass. During the manufacturing process, rollers apply high pressure to the inner barrel, compressing the aluminum into its final shape. This effectively eliminates porosity and aligns the grain structure of the metal, which increases tensile strength. The end result of the Flow-Forming process is a lightweight and extremely strong barrel that equals that of a traditional forged wheel at a fraction of the cost.
    3. Weight & Strength Optimization
    We didn’t just redrill and recycle our BMW 5x120 SM-10 design, we’ve rebirthed it. After seven months of Mustang-specific optimizations, we’ve minimized weight while maximizing strength. Strength tested to surpass the 5x114.3 JWL/VIA’s standard, and enthusiast tested to beat their weight standard. Since most Porsches have an inherent rear weight bias and run wide rear wheels, we’ve strengthened the inner lips. The result is a lightweight wheel with extra strength in all the right places. Use the SM-10 with confidence on both street and track.
    4. Warranty
    All APEX wheels are backed by a 2 year structural warranty and a 1 year finish warranty to the original. This warranty guarantees that all APEX wheels will be free from defects in materials, workmanship, and paint finish under normal and reasonable use.
    Finishes
    [​IMG]
    Sizes, Weights & Pricing
    Questions about tires, fenders, brakes, spacers, or suspension clearances?
    Click here to review our helpful chassis-specific fitment guides.
    Face Profiles
    [​IMG]
    On-Car Photos
    [​IMG]
    [​IMG]
    [​IMG]
    Tire Mounting & Balancing Service
    [​IMG]
    Popular street and track tires are now available when you order APEX wheels. Add tires with your wheel order and get free tire mounting and balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse. With our competitive tire pricing bundled with the savings of free mounting and balancing and convenience, it’s the ultimate wheel & tire package.
    *Note: Tires will only ship mounted to the wheels in your order, and can not be sold separately. Tires and wheels must be purchased in the same transaction. Tire-only orders will be canceled and refunded.
    Available Tire Brands:
    Ordering & Contact Information
  2. APEXRaceParts
    395
    505
    Jan 23, 2017
    Bay Area, CA
    Many have asked us about the great features and details of the SM-10 wheel design, and while images are helpful, they simply do not do the wheel justice. We took things a step further by creating the following video.
    - Cory
  3. Bill Pemberton
    Bill Pemberton TMO Addict
    2,560
    1,315
    Sep 30, 2011
    Dear Apex Wheels,
    Please give us a bit more information , this thread is so bare of real data -----------NOT!! Geez, Cory, I may be an Apex fan , but a lot of it has to do with the extreme dedication you guys have to our fairly small group. I know I have mentioned to my show car buddies that they need to check out your rims, but making a wheel for TrackusRaticus folks is a niche market and I hope everyone on TMO realizes how few companies really look at the issues a track wheel may experience differently than one just for cruising. Thanks again , and I will try not to be such a FanBoy, but I for one appreciate all the hard work, dedication , activity on our Forum. The service after , during and before the sale is phenomenal - best of luck with the new wheel.
    lil’Zeus and Red5OH like this.
  4. gripdriver
    gripdriver TMO Race
    236
    127
    Jun 27, 2017
    Arizona
    these wheels would be killer in silver 18x10 and 11...
  5. 32vsnake
    32vsnake TMO Beginner
    Oct 16, 2016
    victoria
    19x10 square for me.... Group buy on the sm-10 please ;)
    TymeSlayer likes this.
  6. TymeSlayer
    TymeSlayer Tramps like us, Baby we were born to run...
    2,523
    1,237
    Dec 12, 2011
    Brighton, Colorado
    Since Sweet Lorraine is already sporting a nice set of 19x10 EC-7s - she'd like a different looking set like these SM-10s in matte black.
  7. APEXRaceParts
    395
    505
    Jan 23, 2017
    Bay Area, CA
    Ha, you had me going there at first ;) Thanks for the kind words, Bill.
    I agree, we would love to produce them in 18" sizes and could if the demand picks up for it.
    Be on the lookout within the next few months. We are getting a fresh stocking order of these babies in just a couple of weeks too!
    - Cory
  8. APEXRaceParts
    395
    505
    Jan 23, 2017
    Bay Area, CA
    As promised, the SM-10 is finally back in stock in our most popular sizes after a long hiatus.
    19x10" ET40
    19x11" ET26
    19x11" ET52
    19x11.5" ET56
    All are here in pretty much the full complement of finishes, ready to go out. Get your orders in now before they're gone!
    David's GT500 is sporting our 19x10" ET40 squared set with 285/35-19 Michelin Pilot Sport 4S at all four corners which provide this big powered car with equally big grip.
    [​IMG]
    - Cory
  9. lil’Zeus
    lil’Zeus TMO Intermediate
    13
    10
    Feb 20, 2019
    Lake of the Ozarks MO
    FC1DBC80-2E6D-4268-9834-3F5622CB4011.jpeg I love mine so far!
    APEXRaceParts and Bill Pemberton like this.
  10. TymeSlayer
    2,523
    1,237
    Dec 12, 2011
    Brighton, Colorado
    Love my SM-10s. Can't wait to get 'em on my Boss. Pictures to come... I promise.
  11. ArizonaBOSS
    ArizonaBOSS Because racecar. Moderator
    8,128
    1,724
    Dec 6, 2010
    @TymeSlayer there is a guy out here that has a KB Boss with Anthracite SM-10s and they look GREAT.
    APEXRaceParts likes this.
  12. TymeSlayer
    2,523
    1,237
    Dec 12, 2011
    Brighton, Colorado
    I've thought about Anthracite but all my wheels are satin black and give the KB Boss a more menacing look. This included my Apex EC-7s and my new SM-10s.
    BTW, spent the past weekend down in the Scottsdale area (Spring Break with the family) and the weather seemed perfect for tracking (Mid-80s). I can't imagine running down there in the summer.
  13. APEXRaceParts
    395
    505
    Jan 23, 2017
    Bay Area, CA
    SALES ARE HERE FOLKS. From now until the end of May, all 19" SM-10 wheels are up to 20% off! Grab them now just in time for track season. View the inventory here
    [​IMG]
    - Cory
    cholmes1, TymeSlayer and The_Dead_Cow like this.
  14. TymeSlayer
    2,523
    1,237
    Dec 12, 2011
    Brighton, Colorado
    Love my 19x11 SM10's. Got the RE71R mounted on them but I'm using up the rubber on my EC7s and then I'll post some pictures of them on my '12 Boss.
    cholmes1 likes this.
  15. Mad302
    Mad302 TMO Race
    354
    119
    Sep 2, 2014
    Waco, Texas
    Here's mine after a little track work
  16. bulldogracer
    bulldogracer TMO Intermediate
    67
    Oct 20, 2011
    Michigan
    Yes I would be interested in 18x10 or 11 in race silver too. Mad that I missed the group sale on the EC7's earlier this year. Any chance for 18's this year?
Share This Page
