boardkat
CAMtard
Apologies for starting a new thread, but all the existing ones I found seem to be S197-specific.
Wondering if anyone has rolled their own oil and/or transmission cooling on a 15+ GT w/ MT-82? My engine blew up (again), so I figure I'll finally do proper oil and transmission cooling while everything is out, given my desire to start doing Optima and TT-type events.
Looking primarily for feedback on the best locations to use/tap the transmission case for inlet/outlet and temp sensor bungs. Also interested to hear about the effectiveness of the various cooling options that Setrab offers - was thinking of going with the 172 for oil cooling (seems to be what the OTS Cooltech option uses), but haven't yet decided what would work best for the transmission - maybe another 172 w/ a Tilton pump? That's what I'm using currently for my FTBR-based diff cooling setup, but wasn't sure if it could provide enough pressure for a bigger cooler?
Caveat to all of this is the space I have available - I'm running a massive triple-pass 970cu inch heat exchanger for my supercharger - but I did remove the AC condenser, so there's room between the exchanger and the radiator. I do wonder about having three layers of cooling jammed in there though, and the decreased efficiency that results (but hoping the radiator being furthest back, but without the load of needing to cool the oil, will negate the poor location).
Anyway, not looking to reinvent the wheel, if there are threads/posts here that would be helpful, please point me in the right direction!
