A couple of questions of the PP1 front Brembo calipers, and the rotors.
On the calipers, the middle bolt. Mine keeps spinning when I try to torque it. Can quite fit a 17mm wrench to hold it in place. Is there a special wrench to keep it held in place?
Front Rotors: This is the second set where I've had this happen. The outer edge doesn't wear down and creates a weird, inconsistent edge. Am I the only one that has this problem?
