2012YellowBoss said:Ended up getting a set of these
M-1007-DC1895 05-12 SVT 18"X9.5" WHEEL / http://www.trueblueracingparts.com/05-12-SVT-18X95-WHEEL_p_111.html
It is the Ford Racing wheel, now I have what I wanted, a set of 10's and 9 1/2's. Have not tracked them yet but mounted a set of 275/40's on them - heat cycled ready to go. They look a little different but you need to study them close to really see the differences.
Berol said:Scott, I have the same SVT 18" wheels. Which wheels are you running for your 10's? The ones you've had for a while?
2012YellowBoss said:Berol said:Scott, I have the same SVT 18" wheels. Which wheels are you running for your 10's? The ones you've had for a while?
Still using the 18x10's from CrusinConcepts for the rear, the set works out well. While the 295/15's I am running call for a 10.5 rim it is very close to having the 10 as the correct rim width. The 275/40's up front call for the 9.5. I do have an extra set of track rims 18x10 and 18x9 with the same tires and they work without any issues I can see but if I knew about the other setup I would have two sets of them.
I am going to run a set of NT01's front and the NT05's (same sizes) when I burn out what I have now. If they made the 01's in a 295 I would try them but I don't want to have to buy more rims for the size they offer now. After that I am going to get a set of R6's to have some fun at Sebring. For normal tracking days the NT05's hold up very well and I still go faster every time I run so plenty of room left to learn with them.
Yikes. I straddled one on Turn 3 at BIR doing probably 60 (2 wheels off ;D) and was pleasantly surprised I didn't rip mine right offArizonaGT said:I am excited to lower the car sometime late next year, however I am scared of getting the trans scoop ripped off on-track. Already scraped it a little bit this last event being aggressive with one of the curbs. I'm going to have to be careful.
itrack said:Order some 18x10 Gt500 repro's for the Boss. I picked up 16 Viper Cup Michelin take offs this weekend so it looks like the boss will be on some big meats next time its on track. Figured I let you guys in on this deal I found, $447 to my door.
http://www.cruizinconceptswholesale.com/proddetail.asp?prod=GT500WHEEL18X1045MM
Google found a 5% coupon for them as well. I'll post pics of them once they are in.
My SVT PP wheels are made in Taiwan.lbp said:Whoa.... Chinese wheels on the track???
Even under the best of circumstances I have seen quality wheels such as Fikse & BBS break on the track with disastrous results!
I have two sets of the same wheels painted black in staggered 18 x 10.5 and 18 x 9.5 sizes. I don't need a third set.ArizonaGT said:What are you replacing them with?
smitty, my other two sets started out this way. I had them painted gloss black for $50 each and they held up great all last season. I'm sure you could find someone to paint them for that down there.smittytx said:If they were black they'd be mine.
cloud9 said:smitty, my other two sets started out this way. I had them painted gloss black for $50 each and they held up great all last season. I'm sure you could find someone to paint them for that down there.smittytx said:If they were black they'd be mine.
smittytx said:Ok, maybe I misspoke. I should have said...
If I wasn' getting ready for NASA by buying two sets of spare pads, a spare set of rotors, a spare set of tires, changing all of my fluids, fixing my trailer AND if they were black, they'd be mine.
