You need a 2% cash back CC. 8)2012YellowBoss said:LOL, when I cash in my 1% cash back on my credit card with all the recent mods - I can get a new set of Hoosiers!
cloud9 said:I have a set of 4 Enkei PF01 18 x 9.5 45mm offset wheels with TPMS and only two track days on them for sale. They are virtually brand new. These are the best lightweight track wheels for the money weighing in at 20lbs. That's a savings of 11lbs per wheel over stock. Here's a pic of them on my car. $1200 shipped.
Uploaded with ImageShack.us
Grant 302 said:Thanks for getting back to me. I guess it's the D-Force rims for the GT. Although I worry about getting the custom D-Force without picking up a at least 1 spare or a 2nd full set.
JScheier said:Grant 302 said:Thanks for getting back to me. I guess it's the D-Force rims for the GT. Although I worry about getting the custom D-Force without picking up a at least 1 spare or a 2nd full set.
D-Force has been pretty good. When I got my first set for my M3, they were 'special order'. Since then at least 10 dealers are carrying them including TireRack. If the Mustang ones sell... and I'm sure they will... I'm betting many dealers will pick them up.
BossJockey said:I was wondering if these would fit the front and rear of our car. The web page says rear only but with a 42mm offset I'm thinking they would fit. (only 1mm less than the D-force 18x10s)
http://www.americanmuscle.com/glossblack-forgestarf14-19x10-0512.html
Question to NT05 tires users. How are they in the wet?
BossJockey said:Question to NT05 tires users. How are they in the wet?
POS VETT said:Forgestar wheels don't have much clearance for the Brembo caliper. I tried to get 11-in width for the front and their wheels can only clear the caliper with 9-in or maybe 9.5-in if you don't mind lower offset. This was about 2 months ago; give Forgestar a call and see if anything has changed.
Dean#4AI said:POS VETT said:Forgestar wheels don't have much clearance for the Brembo caliper. I tried to get 11-in width for the front and their wheels can only clear the caliper with 9-in or maybe 9.5-in if you don't mind lower offset. This was about 2 months ago; give Forgestar a call and see if anything has changed.
I hope they fit. I have a set of F14 18x10's on order. It won't be a big deal if I have to use a small spacer though.
Thanks Scott. I've seen mixed reviews on them in the wet. Everybody seems to like the dry traction.Question to NT05 tires users. How are they in the wet?
Never did a lot of street driving on them but I have a few track days in the rain and they worked very well. They have a good rain rating because of the two wide channels in them I guess.
BossJockey said:Dean#4AI said:I hope they fit. I have a set of F14 18x10's on order. It won't be a big deal if I have to use a small spacer though.
What offset did you get?
It's going to be tight. With an 18 x 9.5 45mm offset and 275/40/18 NT01 I had between 1/4"-3/8"" to the strut. The 10" wheel moves you 1/4" closer and 3mm more offset moves it 1/8" further away leaving your tire roughly 1/8"-1/4" from the strut. Might need 1/4" spacer.Dean#4AI said:BossJockey said:Dean#4AI said:I hope they fit. I have a set of F14 18x10's on order. It won't be a big deal if I have to use a small spacer though.
+42
I was referring to the fronts in this post. The rears will be no problem. Plent of room to the bumpstop bracket with an 18 x 10 +42mm offset.cloud9 said:It's going to be tight. With an 18 x 9.5 45mm offset and 275/40/18 NT01 I had between 1/4"-3/8"" to the strut. The 10" wheel moves you 1/4" closer and 3mm more offset moves it 1/8" further away leaving your tire roughly 1/8"-1/4" from the strut. Might need 1/4" spacer.Dean#4AI said:BossJockey said:Dean#4AI said:I hope they fit. I have a set of F14 18x10's on order. It won't be a big deal if I have to use a small spacer though.
+42
