Deciding between these 2
Website under maintenance
www.gregsmithequipment.comAdvantage DX-9000-HD | 9,000 LBS. 4-Post Lift
The Advantage Lifts 4-post lift DX-9000-HD is tailor made for residential garages. A five-year warranty along with all of the auto lift accessories you could possibly need. ETL Power Unit. Free standing 4-Post lift does not need mounted to concrete floor. 9000LBS weight capacity.www.advantagelifts.com
i like the greg smith because it can be mobile
Both have caster kits.
I have advantage 9K, direct lift 8K, and Atlas 8K. Got Direct lift first, as it was ALI, but can see
almost no difference between Direct and Atlas. Advantage is 1000 times beefier than either
of the 8K's and way more stable, even up pretty far with my 7700 lb diesel on it.
Atlas I only use for car storage, hence I didn't care much about certification for that one. Advantage is not
certified (yet) either, but it is so overbuilt, it's less of a concern than the cheaper put together 8K's.
One downside to Advantage is you cannot adjust rested heights per corner like you can with other 2. You can only
adjust cable height. Makes a big difference with older floors that are not all that level.
