I aquired my 12 Boss 302 last summer replacing the 03 Cobra that I did track events with for 14 years. The Cobra was a great car, but as with all Mustangs they seem to have an achille's heel somewhere, the Cobra was the rear differential getting too hot and the Boss 302 seems to be the clutch...
I have tracked the Boss at CMP, Road Atlanta and VIR and have experienced shifter/gear lockout. At first I thought it was the driver but after installing an MGW Shifter, Transmission Scoop, seperate clutch reservoir and new hi temp fluid I think the next step will be clutch replacement.
After talking with people at the track, some of them on this forum, forum reviews here and other places, the consesus seems to be to switch out the clutch for a McLeod RST Dual Clutch with their steel flywheel, new throwoutbearing and while in there a s/s clutch line.
I am leaning this way but would like your thoughts and ideas on this clutch and others. The Boss will be on track at 4-5 events per year (10-11 track days) and is driven for fun (going to the beach, mountains) as I have a company car for daily use. I am planning on leaving the motor stock as it does have the track key activated (which is awesome!) The suspension is stock at this time and I believe I need to resolve the clutch/transmission isssues before i go down that rabbit hole.
Your input is appreciated in advance and a question for those who have done the McLeod Clutch are there installation issues that I should look out for and other areas of concern?
