- Thread starter
- #41
Its in the car still and is running great , this one is a little better.NFSBOSS said:Inquiring minds want to know what happened to the other one?
Better works. Your car sounds bad a$$. How high do you rev it?bbrgt said:Its in the car still and is running great , this one is a little better.
NFSBOSS said:Better works. Your car sounds bad a$$. How high do you rev it?
302 Hi Pro said:Hi BBRGT:
Great photos. I was wondering, where are you tapping in to monitor oil pressure and oil temps? Looks link a 1/4 in SS bradded line coming up the left front side to a sending unit at location of cam phaser actuators, not sure.
Also for engine oil cooling, are you running only the air to oil cooler, (as pictured), or do you use both air and coolant to oil coolers?
Thanks in advance for the information. Good luck in the 2014 season.
302 Hi Pro
bbrgt said:
ArizonaBOSS said:Interested to see what that bad boy dynos out at.
Do you use any lower support on that oil cooler? I am replacing the 915-series Setrab (15-row, stock 302S) with a 925-series Setrab (25 row) sometime this week and I'm hoping that I can just get away with the upper bracket mounted to the radiator support such as shown in your picture.
Keep the info coming and good luck!
patrickshelby said:bbrgt said:
It's the Tremec t6060 from the Boss 302R
ArizonaBOSS said:So many goodies, so little time. That's a pair of very spendy clutches! Nice lightweight flywheel as well.
Any plans for the "old" engine?
No, its a big bore with diamond racing pistons , manley rods , ported heads , CJ cams and upgraded valve springs , I will video the dyno runs .ArizonaBOSS said:Sweet Jesus, it's beautiful! Is it a "regular" (lol!) BOSS engine w/ CJ intake or is it a full-on Aluminator XS?
FRPP sure is focused on improving the 302S with each year. I remember seeing all the improvements on the 13 vs. the 12, and now that clutch on the 14s...I wonder what other goodies went into the 14 cars.
In for Dyno! Get a video if you can?
Who made the front cross member I see the sway-bar bolted to ?bbrgt said:
