Asking $19,500
Selling My * One Owner! * 2012 Mustang GT * Brembo Pack * 6-Speed Manual *
Florida owned car so you don't have to worry about salt rust, this car has never had a major issue its honestly so reliable. Tints on all window for sun protection. I always put 93 octane in for the engine. I'm a car enthusiast so this car is well sorted.
Very well maintained:
* New EBC brakes a year ago * New Michelin tires 3 months ago * Highest quality oil used and changed every 6 months * Transmission fluid and differential fluid changed a year ago * New Battery a month ago * Dealer Services done *
This is the lightest-weight Spec this car can come in:
* No sunroof * No Navigation * 6-speed manual * No Spare tire *
Factory Options that come on the Brembo Pack Mustang:
- Larger Brembo brakes up front, 14" disc w/ 4 piston caliper
- Stiffer GT500 rear Lower control arms
- Stiffer struts and shocks
- Larger 19x9" wheels
- Sport Mode Traction Control
- Sport and Comfort Steering Modes
These options add up to make this a really fun mustang that can handle well and put the power down. I've also added some light performance modifications to the car to make it perform even better. All aftermarket modifications I've made are the highest quality manufacturers and aren't invasive to the car.
Performance Modifications:
- H&R Sport Springs
- EBC Discs and Pads on all four corners, Front are vented discs, Pads are Yellow Stuff performance pads
- Roush Axle-back, sounds AMAZING and ~40lbs lighter
- Michelin Tires all four corners, PS4S up front, AS 2+ in rear
- Barton 2-post Shifter Bracket, no more high rpm lockout
- Steeda adjustable street Panhard Bar, stiffer and lighter than stock
- K&N drop in air filter
Styling Modifications:
- Aluminum Gloss Black bar front grille, looks way cleaner and hides fog lights behind
- Raxiom LED foglights
- Foose cueball shifter
- "COYOTE" third brake light tint
- Boss 302 style body color spoiler
- Shelby Snake wheel center caps
If you have any questions message (786)-514-5174
I'm usually in Tallahassee, FL where I go to school if your interested in seeing the car.
