This is the wheel for the track pack equipped cars.....LOVE the Alcantara wheels!!
Install TIME!!
SOO nice!!
Installation: **probably a good idea to go ahead and disconnect the battery cable before install**
Remove the 2 caps from the side of steering wheel
Then remove the 8mm bolts from each side
Gently remove the airbag assembly
Remove the Black and Grey connectors from the air bag assembly
Set air bag assembly aside
Disconnect the black plug
Remove the 24mm bolt from steering column
Gently remove steering wheel
The new wheel comes fully assembled with wiring harness and everything!!
Attach new steering wheel
Connect Black plug
Torque 24mm nut to 45ftlbs
Reattach air bag/plugs....black to black and grey to grey
Gently slide the air bag assembly back into place, making sure holes are aligned....if you are really good you wont even honk the horn and scare the $hit out of yourself
Install the 8mm bolts, and caps
and now the fun part....removing the protective film!!! :rockon:
Install TIME!!
SOO nice!!
Connect Black plug
