2018 gt350 clutch problem
i took 2018 gt350 to the track, and when i shift from 3rd to 4th, the clutch pedal stayed down and won't go up in at least 1 sec. i thought i was doing money shift and try to hit the clutch and i didn't find it.. so i have to press the clutch for 1 sec until i let it go for the rest of track day. it only happens on track not during normal driving.
That’s not good. Have you installed the Steeda clutch pedal spring?
I don’t know if that will solve your problem and it seems that I recall someone else removing the spring (for other reasons) and there was too much slop in the travel. Give it a try if you want just be careful not to break the plastic piece that is part of the assembly. I do not believe that piece is available without purchasing a whole pedal assembly.
just order a clutch spring... i will see how that goes..
