Can I use my existing Aluminum flywheel and Ram clutch that I had balanced to my engine with a 2018 Mt82D? I read the input shaft is longer.
no totally different input shaft length. Need to use a clutch and flywheel setup specific to the Dual mass setup in the 2018+ cars. Why would you want to use this trans anyway? the gearing is useless for the track.Can I use my existing Aluminum flywheel and Ram clutch that I had balanced to my engine with a 2018 Mt82D? I read the input shaft is longer.
