350R front wheel stud length
675
253
Can someone let me know about the front wheel stud length on a 350R? Specifically, are they long enough to run say a 5mm spacer without problems? I know 5mm is more than would be comfortable on conventional length studs but my understanding is the 350R has slightly longer studs.
Thank you!
675
253
Awesome, thank you guys!
Just for my own edification, the rear studs are not as long, right?
675
253
Are the rear lugs conventional length or are they slightly extended as well? In other words, are they capable of also using say a 5mm spacer and still have enough threads?
2,203
1,067
Bay Area
The rears are slightly shorter than the front. I dont recall that length off the top of my head . I think you’ll be fine with a 5 mm spacer. There is a guy running 12” wheels in the PNW and I think he is on TMO so you could use the search button and there might be some data there for you.
PaddyPrix
728
1,088
San Diego
For what it's worth, and lovingly stolen from the TMO Facebook group -- (hoping the hot-linking works)
Timothy Hilliard
Left to Right:
OEM S550
OEM S550 Mag Ride/GT350
ARP 100-7732
OP Mid Length
ARP 100-7733
OP IMSA GT4
OEM GT350 R Front
OP RSPEC
The stock R350 rear should be right around 3-4th, and good for 17mm of spacer.
