So what if Ford didn't make the new 5.2 FPC and had stayed with a 5.0 (or even 5.2) CPC and used the new intake or the CJ intake and put the hotter cams in it and spun it up to 8,500 RPM's? Which would you rather have? While the FPC is really cool won't adding counter weights, or whatever they did, to keep it from vibrating apart take away from the advantages of a FPC? I guess you keep the improved exhaust flow but I have to wonder. You know Ford has a couple of 5.0's they've tweaked on sitting around. Plenty of people including a couple of BMO members have 5.0's putting out 500+ at the crank so if they can do it you know Ford already has. Thoughts?
