- 66
- 39
Here is a comparison of the Gen 1 and Gen 2 5.2 blocks. I have both on hand at the moment. I will be shipping the Gen 1 back by end of week so if anybody wants any specific differences that I don't cover then just post up.
So now it is time for "whats different in these pics"
I am hoping this link to my smugmug account works! It has all the pics I have taken so far.
https://aceone.smugmug.com/52XSv20/n-cV59vC/
Gen 2 is one to 1.5 pounds heavier.
The valley area is lower and flat compared to the gen 1 valley that is slightly humped. Makes the cross rib supports stand out more but really the "floor" is lower.
The lower drilled cooling ports between the cylinders are modified with a corresponding modification in the heads for "improved" cooling ? There are small triangles between cylinder bores where they drill a cooling port between the bores.
The air port into the rear bearing cover is more restricted?? smaller oval and not opened on the bottom side of the hole toward the top of the bearing cap.
The head bolts holes are 128 mm deep as opposed to the 71mm deep threads for the headbolts. This will affect cylinder bore diameter/taper with/without deckplates. I am checking bores now for custom pistons.
