A/C Delete Kit for 2012 Mustang GT ?
302 Hi Pro
2,009
441
Southeast
I don't think you will need a kit.
For the under hood portion of your a/c system, the 2012 GT 5.0 Coyote should use a separate A/C compressor belt, (stretch belt, no tensioners) so no A/C compressor removal kit is needed.
Take a look at your GT A/C compressor drive belt, it should be the same as the 2012 Boss 302 U-Code engine.
Let us know what you find out.
302 Hi Pro
I don't think the GTs have the same A/C arrangement. The Boss A/C belt doesn't have a tensioner and uses a Boss specific belt. There's a kit to change that to a tensioner setup from LMR. CR3Z8620AA
I gotta look at the GT when it stops raining. Pretty sure it's different than the Boss.
It depends how much you're going to delete. Everything can be unbolted and removed, but if your going to leave everything behind the firewall, you'll want to plug the lines there. I'll try to find Gary's thread on his A/C removal.
Looks like the same type single belt/no tensioner on my '11 GT. The Boss just has a different, Boss specific belt.
This is Gary's a/c removal thread:
AC: Fix it or junk it?
There's a tool to remove the belt that 'walks' the belt off the pulley. Most just cut it.
Recover the fluid and start unbolting.
