- 6,394
- 8,275
Copy pasta on the relationship between tire pressures and temperatures. While this article addresses things like absolute pressures, and misc other engineering type jargon, what I want you to concentrate on is the methodology on how it's applied. This is what I touched on in the original tire setup thread. If you follow this line of thinking, it will allow you to pressurize your tires at home, and simply bring a small container of nitrogen with you to the track to set your pressures.
The key to this is to
A: establish a "cold pressure" keeping in mind, a "cold" pressure is absolutely useless without a temperature reference.
B: establish a "hot" temperature that works for your car, that is harder than it sounds since temps and pressures need to be taken as the car arrives on pit lane..which requires a crew...which usually requires some dedicated friends/drinking buddies or a budget of some sort.
The "hot pressure" that works for your car can then be applied to the following days "cold pressures". As an example, if 28psi has been determined that it is the optimum "hot" pressure, then , when the car comes in, remove any pressure over that magical 28psi. Then when the tires cool, you have a new set of "cold' pressures to start the day...or any other day at any other track for that matter.
Now, there are two pitfalls,
1. do not..EVER..take hot pressures down to the original cold pressures between sessions, this is a common mistake among newbs. This will throw off the new "cold" settings and might even allow the car to go out with grossly underinflated pressures when cold, causing the tire to come off the wheel. (it is for this reason we use CCW wheels exclusively, the BBS wheels on the Prosche, we have to really watch cold pressures because they won't stay on the wheel).
2. during the day, if you choose to make a tuning change by letting air (preferably nitrogen) in or adding it, you must add it to whatever the current pressure is at the time. I will repeat that, Once the tire leaves it's nice shady all the world is ambient temperature, then things change immediately, this is why it's important to baseline ALL your tires in the morning, before sun hits the cars...etc. once the car moves, engines start, sun come out, pressures change right away, and you've lost your baseline. So, you add or subtract pressures to whatever pressure is in the tire, no matter what the tire says it is.
You can also do this....
1. if you have a spare set of tires that you may use during the day, baseline them as well and when you make a change to the tires on the car, write it down, and put that on the spares as well, that way, when the driver wants a new set of stickers to boost his ego, your stickers will have the same pressures as the tires that came off....essentially no accidental tuning changes.
2. you can also correct your tire pressure to a specific temperature so it is repeatable at other tracks on different days, for me, I use 85 degrees.
Keep in mind this guy uses 1psi per 10 degrees, most engineers use.7, I use another factor based on 5 years of inputting numbers.
and if you're not a "theory guy" you can skip the bold...
How Tire Pressure Varies with Temperature
Based on discussions with the folks at SmarTire, with help from the members of CFG's 996 Forum.
For the range of temperatures and pressures we care about, the Ideal Gas Law
PV = nRT
is a good approximation of the behavior of the air in the tire. In this equation:
P is the absolute (not gauge) pressure.
V is the internal volume of the tire and rim combination.
n is the amount of air in the tire. We won't worry about the units here; you can think of n as being the mass of the air, if you like.
R is a constant. The value depends on the units we use; again, we won't worry about it here.
T is the absolute (i.e. above absolute zero) temperature.
It's hard to make much use of this because there are so many variables. For example, there's no easy way for most of us to measure the mass of air in our tires, or the volume of the tire/rim combination.
Fortunately, we can simplify things. For a given radial tire on a given rim, the volume is essentially constant over a wide range of temperatures and pressures. (This is not true of bias-ply tires, and it's one of the reasons why it's hard to tell from a quick look whether a radial tire is underinflated.) Once you've inflated the tire, the amount of air in it is also essentially constant. So most of the time, the only things that vary are the pressure and temperature, and that variation is nice and linear:
P = (nR/V) T
The first step in making use of this is to measure gauge pressure (let's call it P') and relative temperature (let's call it T'.) If you have a SmarTire system or equivalent, you can read these two values directly. Otherwise, you'll need to wait for your tire to reach equilibrium with the outside air and use the outside temperature as an approximation for T'. You can measure P' with a regular tire gauge.
The next step is to convert from relative to absolute units. I'll use the old Imperial units here because most people reading this are in the US, but conversion is straightforward.
To change PSI gauge to PSI absolute, just add the atmospheric pressure at your location. The standard value at sea level is 14.7 PSI.
P = P' + 14.7
To convert to absolute temperature, add 459.7 (the difference between absolute zero and zero degrees Fahrenheit, expressed in degrees with the same size as a Fahrenheit degree; this is called the Rankine scale).
T = T' + 459.7
Now you can compute the scale factor:
(nR/V) = P/T
I inflated my C4's tires to Porsche's standard recommendations for the street (225/40-18 -- 36 PSI at 68 degrees F, 265/35-18 -- 44 PSI at 68 degrees F). Then I took several measurements with my SmarTire system, and averaged them to reduce measurement error. The results were
(nR/V) = 0.0962 [for 225/40-18]
(nR/V) = 0.1110 [for 265/35-18]
If you convert this information into equations using ordinary gauge pressure and Fahrenheit temperature, you get these:
P' = 0.0962 * (T' + 459.7) - 14.7 [225/40-18]
P' = 0.1110 * (T' + 459.7) - 14.7 [265/35-18]
These are good approximations of the temperature and pressure for the given tire/rim combinations when the initial inflation follows Porsche's recommendations for the street.
Now, suppose you're getting ready for a track session, and want to drop the initial tire pressure. How do the equations change?
Essentially what we want to do is change the value of n in the Ideal Gas Law equation. Fortunately, if the temperature is held constant the equations are linear with respect to n, so we can get a good approximation of the effect of changing it by taking just one more measurement.
I set up this measurement just like the one above, but then I bled enough air from the tires to drop the pressure to about 4 PSI less than Porsche's standard values. The results were
(nR/V) = 0.0886 [225/40-18]
(nR/V) = 0.1040 [265/35-18]
So at roughly 4 PSI below stock (measured at 68 degrees F), the equations are
P' = 0.0886 * (T' + 459.7) - 14.7 [225/40-18]
P' = 0.1040 * (T' + 459.7) - 14.7 [265/35-18]
Furthermore, from this we can see that changing the initial pressure by 1 PSI changes nR/V by about
0.002 per 1 PSI at 68 degrees F [225/40-18]
0.00175 per 1 PSI at 68 degrees F [265/35-18]
(Keep in mind that these are approximations, and probably have a bit more error than the other variables we've been measuring.)
Now we have what we need in order to make a chart showing how pressure and temperature vary.
For the fronts:
And for the rears:
You can create charts like these for your own tire/rim combinations. But once you have them, how do you use them?
You start by making a measurement of temperature and pressure (waiting for the tires to cold-soak, etc., just like above). Then look on the chart for the line that's closest to your measurement. That line will tell you how the tire's pressure will vary as the internal temperature changes.
What if you don't have charts that describe the behavior of your particular tires and rims? Well, a good rule of thumb is that pressure varies 1 PSI for a temperature change of 10 degrees Fahrenheit. (You can see from the charts or equations that for my tires and rims, that's accurate to about 10%.) So for example, if you measure your tire pressure at 90 degrees Fahrenheit, the "standard" pressure at 68 degrees would be about 2 PSI less than what you measured. If you want, say, 44 PSI at 68 degrees, but it's 90 degrees outside, then put some extra air in your tires, wait for it to adjust to the outside temperature, and bleed or top off the tire until the gauge reads about 46 PSI.
That's it! I hope you found this helpful.
PV = nRT
P = (nR/V) T
P = P' + 14.7
T = T' + 459.7
(nR/V) = P/T
For the fronts:
And for the rears:
