A great day followed by a BAD night - rear brake issue
Duane Black
Curbs go brrrppp
581
415
Durham, NC
So I just posted in the lap times - setting a 2:15.83 for a new personal best at VIR and having a great time instructing a student in a Corvette made for a spectacular set of days at VIR - great weather, great times.
That night things went to shiznit. On the way home, the pedal felt SOFT. I thought I must have boiled fluid, but checking my master cylinder revealed it EMPTY!!!! (or almost). In my garage a puddle quickly formed around the left rear wheel. My original calipers got "sticky" several weeks back and were both replaced. The new one was now leaking BADLY!! I took it O'Reilly and got a new one under warranty, which was another issue concerning it came with no e brake spring and I had to go back and get the one off my old one, which led to an interesting exchange between me and a manager.
I'm thinking this may have been related to the fact that my rear brake pads were VERY low, maybe an 1/8th inch left when I took them off- yikes!! paper thin.... my fronts weren't much better. So I have a couple of sets of rear pads and I got some new front pads ordered from Porterfield just this am as I type.
Has anyone else had this issue with replacement rear calipers? Is there a brand I should target? Should I get the O'Reilly shiznit off the car ASAP before it gets me killed? I'm thinking if these parts store calipers were bad, there would be crash in Lemons and Champ every other lap related to it.
I got my daily driver pads in for the week and am just super paranoid now, it took me about 3 hours to get everything squared away last night.
Days like the ones I had made me love this and want to kepe pressing on at this. Nights like this, however, make me just want to rest on my laurels and move on to other things.
I suppose I could use advise on brakes and words of encouragement to carry on.
8,496
8,493
Duane, hang in there , as I have had similar things happen and the main cause is often simply that I was getting faster. You set your best time this weekend, were hitting much higher speeds and on a fast track. Really not a big surprise and I think your concern is more of a simple " heads up," of needing to check your pads more often. Similar issue , years back , made me realize I needed more aggressive pads , as well as needing to check more often. I actually kept the same brand of pads , but moved up onto a more aggressive one. I assumed since everyone else was using the same pad as I was, with no problems,yet I was running quicker than them and should have realized more speed ,more wear. Good luck, nice times at VIR, and enjoyed the video!
Duane Black
Curbs go brrrppp
581
415
Durham, NC
That pad wear caught me a bit off guard - I'm driving faster, braking deeper, on stickier tires, and they aren't lasting as long as they used to - damn things must not be made as well as they used to be! LOL.
The brake caliper bleeding out of the piston on me nad making a puddle under a wheel is the most concerning thing. I can buy pads or take fewer sessions and sleep at night. This caliper shiznit has me shaken though.
Duane Black
Curbs go brrrppp
581
415
Durham, NC
ST43 Raybestos. This was their 5th event - Roebling was a 3 day event with my instructor clinic (10 sessions?), then VIR in October (7 sessions), Roebling Road in January (6 sessions? maybe 7?), then Road Atlanta earlier this month (7 sessions) and then VIR this past week (7 sessions.) I'd say they've had a good run....
8,496
8,493
Keep in mind there could be quite a few causes, and one could even relate to excessive heat build up if your pads were close to metal on metal, but I would just put on your new ones and check more often the next time you are at the track?
7,551
5,283
Duane
I had the same issue with rebuilt rear calipers on my Boss. I swapped out the originals because they showed signs of being hot....a lot. So, i bought a set from Advance, one lasted a single day before leaking, the other is on its third year. There are not that many rebuilders for calipers. The stores/chains don't rebuild, they buy in lots. So moving from one store to another may not get you to a different rebuilder.
Advance track will decide that its needed and turn back on. Got to love computers. I smoked a set of rear pads in one day before i swapped out the ABS module.
Duane Black
Curbs go brrrppp
581
415
Durham, NC
Mine did that but being an automatic, I drive with two feet. I haven't had the issue on 200tw tires primarily and my "skinny" 285 wides. I figured out if you ever got both feet off the petals and let the car "free wheel", it would turn on traction control. If you stayed in control of hte car, even just a TINY FRACTION of braking and gas, it wouldn't engage... probably a chore in a 3 pedal car though. On RE71R, I would engage advancetrac in hog pen at VIR and occasionally at NCCAR for autocrossing. It seemed going to RS4 negated that issue.
899
545
I would put on a set of new Motorcraft / Ford OEM built calipers. I have seen them run down into the backing plates without leaking. I have also routinely seen the rears run down like you are talking about without leaking.
xr7
TMO Addict?
719
841
Minnesota
I would pop the caliper apart and inspect the seals, perhaps an inferior seal has melted. Calipers aren't that difficult to rebuild and you can use a quality part rather than trust the junk sold at most of the auto parts stores.
7,551
5,283
A caliper without E-Brakes is straight forward. Remove piston, remove old seal, clean caliper bores, clean piston, hone if pitted or scored. Place new seal in the grove, lube with brake fluid or an assemble lube, push piston into bore. Ensure piston is fully seated on the bore and that it slide freely. If it binds, remove and inspect seal, piston and bore.
A few more steps with a E-Brake.
DANGER Will Robinson. Be Very cautious if you remove the piston with air pressure. If you have a regulator on your air supply, crank it way down. Under 5 PSI. If possible put a small piece of wood in the caliper to catch the pistol if blowing out. Better yet, remove mechanically.
