S197 3V A horse with no name, a build with no name Build Thread
Norm Peterson
Corner Barstool Sitter
939
712
a few miles east of Philly
Well, to say that progress has slowed would be right up there with the understatements of the year(s).
I did get the fire extinguisher bracket more properly put together . . . I don't think I posted this picture before.Revised fire extinguisher mount.JPG
And I did get the rear ride height raised up.
Norm
Norm Peterson
939
712
Between life and a couple of health issues, the Torsen/3.73 modification is still incomplete. I got distracted by re-emergence of the S197 water leak issue. Still not sure I've fully solved it.
But I have at least come to the firm decision to not swap the TR3650 out, at least not at this time. Near as I can tell, I wouldn't be dropping lap times by nearly enough to justify installing a Magnum XL at $4000+, or even a TKX at somewhat lower cost. Whether I even get back out on the track has something to do with this, too.
This decision came out of running quite a number of comparative simulations using a spreadsheet approach that I've been tinkering with since before there was such a thing as PC spreadsheet software.
Here's a basic acceleration comparison. 3rd and 4th gears cover nearly all of the situations on track, absent traffic, so there just doesn't look like there's much to be gained from either 2nd or 5th in the Magnum.
I've got some more detailed plots that aren't quite ready for prime time just yet.
Norm
Norm Peterson
939
712
Exiting a corner in 3rd (5900 rpm shift point with my 4.6), the plots practically fall on top of each other - no surprise there, really.
But even using 2nd with the Magnum doesn't help - you gain a little for the few mph that you're using 2nd, but you give it back with the extra shift and the slightly taller 3rd gear. Way out past 2000 feet, having an 0.80 5th in the Magnum vs 0.68 in the 3650 begins to catch up.Speed and Distance comparisons 3, Magnum XL vs TR3650.jpg
Norm
Boone
Professional Thread Killer
But even using 2nd with the Magnum doesn't help - you gain a little for the few mph that you're using 2nd, but you give it back with the extra shift and the slightly taller 3rd gear. Way out past 2000 feet, having an 0.80 5th in the Magnum vs 0.68 in the 3650 begins to catch up.View attachment 67743
Norm
Norm Peterson
939
712
I've run these 3650 vs T56 several times, and I'm with you. The only reason a T56 is in my future is the torque rating. If I do toast the 3650, I have to go back better, stronger, faster (or whatever the quote from Six MM $ Man was).
A big thank-you for the real-world feedback. It means a lot.
Norm
Norm Peterson
939
712
Well, I'm slowly getting back into this project. I'd gotten only partway through the Torsen/3.73 swap before having to button everything up for a while.
Anyhoo . . . I'm starting to make a little progress. I never was entirely sure the pinion depth was going to be where it's supposed to be but based on notes I'd taken before I think it's going to be close enough. Naturally after measuring pinion head and shimming so I could run the numbers based on the replacement Ratech tool, I stumbled across the one I'd bought before. Grrrr.
The good news is that if my notes were any good, I may be a few thousandths closer with the 3.73 pinion as shimmed to essentially the same thickness as the 3.55 was originally than the 355 was. We'll see . . .
Here's what I put together today for taking the play out of the pinion bearings while doing the Ratech measuring thing. I'd hoped to find a short length of tube, but that didn't happen.
Pinion depth checking setup using and sometimes repurposing available pieces.jpg
A couple of people are aware of why my current progress is slow, but the short story is I'm dealing with a medical issue that from time to time limits what I can - or should - do. Never mind that if I went at it anyway it would make my wife kind of nervous. Maybe I'll have some pinion depth measurements made (and double checked with the tool I thought I'd lost).
Norm
carver
breaker of wrenches
445
599
ontario
Norm
"Keep on trucking" Norm! It's good to stay focused on a project or two. I just had my knee replacement surgery Fri. so I'm out of the driver seat for 4-6 weeks !!! I'm already getting impatient ! Lots of work to finish on my Boss. :hellyeah:
Norm Peterson
939
712
Looks like I'm in for an offset PHB due to my choice of one of the finned aluminum diff covers that are plumbed for cooling. I'm probably only going to use it for any increase in fluid capacity, the ability to drain without having to pull the cover off, and what should turn out to be easier refilling. And for giving the axle vent a better place to live than on an axle tube. Might as well order a spare set of bushings for it while I'm at it.
Norm
Norm Peterson
939
712
The PHB is now ready even though the Torsen/3.73 install is not ready for it.
Turns out that the Ford Performance adjustable PHB ends measure 1.50" wide. The flanges on the supplied bushings are 0.20" (each) for a total width of 1.90". The supplied inner sleeves measure 1.85". For reference I measured about 1.88" for the OE PHB "sleeves", and the FP bar ends with bushings was a substantial interference fit.
Basically this puts the FP's polyurethane bushing flanges in compression rather than the sleeves. Polyurethane will gradually cold-flow, which would reduce the effective bolt clamp load.
So I ground the faces of one set of bushings (I ordered an extra set of bushings/sleeves) down to a few hundredths below 1.85" as installed. I may or may not need to do any shimming between the sleeves and the bracket sides to ensure that none of the bolt load is being wasted in bending the bracket sides down from about 1.88" to 1.85".
I'm also not a fan of on-car adjustability for suspension links. There is the possibility that loosening of the jam nuts over time could allow the carefully set length adjustment to 'drift'. So I Locktite'd the adjuster to the long piece with the red stuff. Yes, this limits adjustments to full-turn increments, but with a thread pitch of 16/inch I'm not worried about being off by even one whole thread. I'll never see a sixteenth inch "error", and I doubt I'll ever be able to feel any difference in the corners. Worst case, it might cost me a couple of thin wheel spacers, which I'm going to need anyway if I go with 295 or wider tires on those 11" wide wheels.
Shown with the shim that I may or may not need.
Incidentally, the little side clearance ought to offer at least a little less resistance to pinion angle change over the range of suspension travel than if the bushing faces were hard-against the brackets.
Norm
Norm Peterson
939
712
As for the rest of the project, I'm going to bail on the use of crush sleeves and go to a spacer arrangement that I'm at least physically capable of working with. And I've sprung for the official pinion flange installation tool, as it's either that or the project will remain stalled.
Norm
