cloud9 said:25??? I only got 21 lbs
What's the fluid worth ?
Good question. Mine went into the dealer recovery equipment so I don't have any idea.Black Boss said:What's the fluid worth ?
cloud9 said:Surgery was successful. It's out. It took us about 2-1/2 hours total. I'll try to relate what I can, but I was more an extra set of hands. Before we started I pulled the radiator cover, air box and intake tube. We ended up putting the front on jack stands and removing the plastic shroud behind the splitter. Had to take out the 6 splitter bolts at the back but not the entire splitter.
We had to drop the oil cooler to get enough slack in the oil hoses to squeeze the condenser out the bottom.
Compressor had several bolts, one a/c line and an electrical connector to remove.
We ended up disconnecting the wiring harness from the PCM and the ground wires off the battery relo kit to gain enough room to fish out this long line.
Here are all the parts. I haven't gotten around to weighing them yet, but I would guess 20-25 lbs. total.
We pulled the rubber gaskets off the condenser and zip tied them to the radiator overlapped by the two larger gaskets that block off airflow so it all goes to the radiator. The push pins weren't long enough to go through the radiator like they did the thinner condenser.
I forgot to take a picture after they were installed and don't feel like going back out and pulling the radiator cover right now
Black Boss said:Hope this helps. Will update with any alternatives on plugging the firewall ports when I get to it tomorrow....
Yea I noticed the oil cooler fins are pretty stout. Did you trim your Nomex or use the whole sheet? It doesn't look like it can go anywhere as it's wedged in there pretty good.Black Boss said:Good move on the Nomex. I noticed no reduction in cooling with it in place, although with the 948 cooler in most of the radiator is protected and the Setrab fins are more robust than the radiator, which in turn is better than the condenser.......
steveespo said:Where do we get the nomex again?
I didn't see the zip tie kit. I don't think mine is going anywhere anyway. It's wedged in there pretty tight.steveespo said:Ordered 2 and the zip tie mounting kit.
I can see how they would come in handy on a sprint car where the radiator sits out front completely exposed.Black Boss said:The zip tie kit is very good. Not your regular zip ties, basically a straight through tie with big washers on both ends.
