There has been some discussion about the MyColor option and if it's a std. feature on the 2013. I have not taken delivery of my Boss yet (hopefully this week!!) but my dealer indicated it should be on the car. To confirm here is the procedure to access:
- Turn on parking lamps or headlights while vehicle is parked and ignition key is in the ON position (car not running)
- Access the lighting options to the Message Center (message center control button below the headlamp switch)
- Push the SETUP button repeatedly until "MyColor 1" is displayed
- Push & hold the RESET button for three seconds to enter the MyColor adjust mode
- the display will show R:1 G:1 B:1 (there are five levels for each color)
- use the SETUP button to select the color you wish to adjust, either RED, GREEN, or BLUE
- use the RESET button to adjust the levels of the three colors R-RED, G-GREEN, B-BLUE
- once set as desired press the SETUP button until "HOLD RESET TO SET MYCOLOR1" is displayed.
- custom MyColor is now saved as "MyColor1"
As I said I can't confirm if this will work but worth a try!!!
