- 332
- 0
OK, I have one of these really neat devices. I also have the oil pressure sensor kit but have yet to install it so I can only monitor what OBDII provides. Any recommendations for road course use? Annunciator thresholds? Thanks!
I installed an oil temp sensor so I track ECT and oil temp. Before that I watched IAT, but it's almost always within a couple degrees of ambient so don't really need to see that anymore. i.e. the cold air intake in our cars works greatChuckP said:OK, I have one of these really neat devices. I also have the oil pressure sensor kit but have yet to install it so I can only monitor what OBDII provides. Any recommendations for road course use? Annunciator thresholds? Thanks!
Would love to Chuck, but it's a 15 hour pull each way. Too far for me and I already have BIR (PCA) and MPH weekends booked in May. Wish it was closer because it sounds like fun!ChuckP said:Gary:
Thanks for the reply. Until I get my oil pressure sensor installed I think I'll just just monitor ECT and annunciate at 245 and also use an RPM annunciator for shift light. I have an Airaid cold air intake so I don't intake temps will be an issue.
Having MM C/C plates installed on Tuesday. Since I drive the car on the street and to/from the track I'm thinking of going with -2.2 camber, stock caster and 0 toe.
-Chuck
P.S. Would you be interested in 3 days at Mid-Ohio in May? PCA Potomac is there first weekend of the month and it's cheap if you can instruct. I'm on the fence about going but if at least one more Boss is there to help me annoy Porsches I think I'm in!
I wasn't able to get a reading on head temp. Are you using Platform 4? What parameter are you picking (i.e. specifically what do they name it)PeteInCT said:Am I the only one monitoring CHT ? In my mind it's more important to watch the head temp vs. the coolant temp. On average, my head temp reading is 12 to 15 degrees hotter than the coolant temp once the car fully warms up.
Ahhhh I tried Head Temp 1 and got a bad reading and stopped there. I need a better flowchart or more persistencePeteInCT said:I am using platform 4, it's called "Head Temp 2" (not "1", that's just battery voltage it seems). Maybe it only works on an LS !! ;D LOL
Here it is, a little hard to read, with Coolant temp on top and Head Temp 2 below:
Did you ever get this verified?PeteInCT said:Am I the only one monitoring CHT ? In my mind it's more important to watch the head temp vs. the coolant temp. On average, my head temp reading is 12 to 15 degrees hotter than the coolant temp once the car fully warms up.
ChuckP said:Maui? Been there...twice. What a gorgeous place! Bet you don't drive your Boss on the Hana Highway. I rented a 4-Runner for that last time I was there.
5 DOT 0 said:Did you ever get this verified?PeteInCT said:Am I the only one monitoring CHT ? In my mind it's more important to watch the head temp vs. the coolant temp. On average, my head temp reading is 12 to 15 degrees hotter than the coolant temp once the car fully warms up.
Remember the PM you sent?PeteInCT said:5 DOT 0 said:Did you ever get this verified?PeteInCT said:Am I the only one monitoring CHT ? In my mind it's more important to watch the head temp vs. the coolant temp. On average, my head temp reading is 12 to 15 degrees hotter than the coolant temp once the car fully warms up.
What do you mean 'verified' ? It's the OBD output for head temp, unless Aeroforce coded their implementation of Platform 4 incorrectly. My assumption on why the channel for "Head Temp 1" only shows charging voltage is because Ford's implementation of the OBD interface chose to use that channel differently. The OBD 'spec' really isn't a specification as much as it's a suggestion on implementation, which varies from manufacturer to manufacturer.
