Here's my personal opinion on this topic. If you don't have a full cage with proper harnesses and neck restraints (basically a race car) don't disable any airbags!
I have a 4 pt roll bar and 4 pt ASM harness (wrap to roll bar). Mostly worried about the air-bag recall thing. Less worried about an off track excursion or something worse.
I just spoke to a dealer about this today since it was on my mind also, and they have no clue when the Tacraps will be replaced. Unfortunately for us, it is in the drivers side... What I have been trying to find is a breakdown of the incidents with years of manufacture listed to try and see if there is a correlation to area and age of the airbag. That way I could figure out just how worried I should be.
In my last track car (SN95) I disconnected both airbags when running at the track. Simply unplugged them from behind. I did have a rollcage and harnesses.
Havent got into the S550 yet to see if the same can be done.
Also would like to disconnect the seat airbags somehow.
Anything happens, it just less expensive to fix without having to worry about 1000's of dollars in airbags and actuators.
Several years ago brushed a rail at a track which damaged the front bumper...both airbags went off. The cost of replacing the airbags was more than fixing the bumper and radiator parts.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
