- 252
- 2
Can anyone give me some advice for air pressures to run on NT01 tires in 275/40/18 on 18x10 wheels for track days?
Thanks!
Thanks!
06mach1 said:So would these pressures work for 305/35x18 NT01's also?
We would recommend a camber angle between -2.5 and -5.0 degrees.
Correct tire mounting should have one side of the tire, usually marked "OUTSIDE" on the sidewall, facing outwards.
Please keep in mind these are general guidelines for setting up your vehicle and the NT01s. The right setup for you would ultimately depend on what you feel most comfortable with.
