Airaid CAI Plug
For those who are running an Airaid CAI and the Boss 302S oil breather and want to delete the hose nipple from your CAI tube...here is a 15/16" plug that plugs the hole.
www.steelerubber.com/firewall-plug-35-1214-20
r/
Eric
Awesome thanks. So this plug is relatively stiff? Wow $9.82 for shipping?
Rick,
It is flexible enough to get it in the hole, but stiff enough that it won't get sucked in (like a door plug for example). Should be no problem with the heat given its a firewall plug. Total cost was $15.83 delivered (UPS)...certainly cleans up the look.
r
Eric
NFSBOSS said:
I received my plug today and I'm happy to report it's very stiff and I think it will work perfectly plugging the hole. I'll install it this weekend.
Eric thanks for posting this.
Installed. I didn't want to pull too much on the breather connector out so I cut the grommet. The plug fits very tight and I had to use a screwdriver to stuff it into the hole and there's no way it's ever going to work loose. I was always a bit suspect how loose the breather connector was with the grommet so I'm glad I've put that behind me. And of course a couple of photos.
