Alloy vs Steel for Moroso oil pan
5,237
4,227
After recent track adventures wanted to get a Moroso oil pan to improve the oil system. Was thinking steel would be stronger, But aluminum would be lighter and help lower temperatures....
Any thoughts???
215
Have you considered the Boss 302S pan? It has little more capacity and you loose 0 ground clearance. It is a bit pricey but this is not something you will be buying twice....
captdistraction
GrumpyRacer
1,954
1,698
Phoenix, Az
I have both. The aluminum one is lighter, but its not the end of the world in weight difference. They're both seemingly strong.
In regards to the duct versus pan, I've hit one against the steel pan riding some curbing I shouldn't have:
The pan won, but I will admit field-welding a steel pan is easier than an aluminum one depending on who you keep for company at track events.
I don't think you can go wrong with either one, but the steel one is a huge value at its sub-$300 price point. I run it right now, but the aluminum one will eventually go on a yet-unknown spare motor for my racecar.
147
60
You might highly consider a steel pan over an aluminum one.
Besides sliding over concrete curbing better (if you track long enough it will happen) it is less likely to gouge out and leak.
No matter how little, this might be one place where you do not want to try and save weight.
Been over curbing and very glad mine was steel. Just sayin'.....
680
215
Not to hijack but Summit is really good with regards to custome service. Keep in mind, they will beat competitors pricing by $1.00....
598
536
My steel Moroso pan crack at Laguna Seca a couple of years back. It was a hair line fracture about 3 inches long where the stump drops down in the front. I replaced with the aluminum one and never looked back.
5,237
4,227
Thanks, My K member is a little skewed to one side anyways.... about 1.5mm. Be a good time to take care of that. Must have shifted after one of my off road adventures.....
218
369
CA
I just got the steel one as my OEM one already scraped.
I am curious though about what ports you used for what sensors. I also got an oil cooler sandwich plate with two extra ports as well.
Dave_W
986
1,278
While the steel pan may weigh more, it's literally one of the lowest points on the car, so much less impact on handling than weight up high.
6,519
8,156
So how effective/necessary is that trans scoop for short sprint races...say 30 min?
captdistraction
GrumpyRacer
1,954
1,698
Phoenix, Az
on a MT82 it definitely seemed to help prevent the shifts from getting scratchy about 20 minutes in, synchro behavior was always an issue with the recommended fluids once they got hot. I don't run one on the magnum (as it has a cooling loop)
However for race duty on MT82 the thicker fluid options (from OPM or "the calimer mix" - latter I'm less a fan of) and the scoop did make a noticable difference, but I'll admit I was never happy with how that setup shifted, and I tried all sorts of shifters and parts.
