Amp upgrade
Hi, everyones, had anyone done an 4 channel amp upgrade on a 2019 ford Mustang gt 5.0l premium 401a. If ao just want to know the colors of the Factory speaker wires at the oem amp. Thanks in advance
Radio 12V Red + Radio, black 24 pin plug, pin 1
Radio Ground Black/Gray - Radio, black 24 pin plug, pin 13
Radio Ignition Brown/Yellow (delayed accessory) + Driver Kick, door harness --or-- BCM in passenger kick, 36 pin plug (J3), pin 30
Factory Amp Turn-on Blue/Green + Radio, black 24 pin plug, pin 7
Power Antenna Yellow/Green + Radio, black 24 pin plug, pin 2
Left Front Speaker (+/-) White - White/Brown or Green - Gray +,- Radio, black 24 pin plug, pins 22 - 10
Right Front Speaker (+/-) White/Violet - White/Orange or Violet - Yellow +,- Radio, black 24 pin plug, pins 23 - 11
Left Rear Speaker (+/-) White/Green - Brown/Yellow or Green/White - Brown +,- Radio, black 24 pin plug, pins 21 - 9
Right Rear Speaker (+/-) Brown/White - Brown/Blue or Violet/White - Blue +,- Radio, black 24 pin plug, pins 24 - 12
Center Channel (+/-) Green - Gray/Yellow +,- Radio, black 24 pin plug, pins 20 - 8
Left Front Speaker - With Amp White - White/Brown (low); Green/Blue - Gray/Blue (mid/high) +,- Amplifier above driver kick, gray 16 pin plug, pins 14 - 13 (low); 14 pin plug, pins 8 - 9
(mid/high)
Right Front Speaker - With Amp White/Violet - White/Orange (low); Violet/Gray - Yellow/Gray (mid/high) +,- Amplifier above driver kick, gray 16 pin plug, pins 6 - 5 (low); 14 pin plug, pins 4
- 5 (mid/high)
Left Rear Speaker - With Amp White/Green - Brown/Yellow +,- Amplifier above driver kick, gray 16 pin plug, pins 16 - 15
Right Rear Speaker - With Amp Brown/White - Brown/Blue +,- Amplifier above driver kick, gray 16 pin plug, pins 8 - 7
Center Channel - With Amp Green - Gray/Yellow +,- Amplifier above driver kick, 14 pin plug, pins 2 - 3
Subwoofer - With Amp Violet/Green - Green/White (preamp); Violet/Red (amp turn-on) +,-; + Amplifier above driver kick, gray 16 pin plug, pins 1 - 2 (preamp); pin 9 (amp turn-on)
Aux. Audio Input Left (+/-) Blue - Gray (SYNC audio) +,- Radio, black 26 pin plug, pins 12 - 25
Aux. Audio Input Right (+/-) Violet - Brown/White (SYNC audio) +,- Radio, black 26 pin plug, pins 13 - 26
Rearview Camera Video White/Green - Brown/Violet +,- Front Control-Display, black 12 pin plug, pins 6 - 12 --or-- SYNC Module-Display, black 54 pin plug, pins 14 - 15
May want to do some continuity checks before applying power to make certain things are correct. From my former audio days this is what I could find.
