domesticpower
Track Addict
Long story short, pressure plate broke and bent the slave cylinder and I need a new clutch. A new clutch was never in the works so my budget is really tight. Going through the forums, it seems like the McLeod RST or Exedy Hyper Single are the most popular ones. Don’t want to get people arguing over which is best; I can’t afford either. Is it worth it to get a lower spec clutch from McLeod or Exedy or should I stick with the OEM which already failed and makes me work hard to avoid the shift lock? If I should avoid OEM still, does anyone have any experience with the lower spec clutches and have recommendations? Thanks in advance.
