Eric said:I went with the oil pan offered through Chicane 23. The pan is made by Armando (he had a long history with Aviad before starting his own company). The pan is a modified coyote pan, so there are no issues with rails not seating and leaking. It also comes with a modified pickup. Finally, it uses the stock low oil level sensor along with the OEM gaskets. Its capacity is 12qts.
http://www.chicane23.com/shop/chicane23-custom-coyote-road-race-oil-pan/
You'll have to drop the K-Member to install it...it fits with the stock k-member though.
[DO NOT buy this pan directly from Armando. You will have extreme problems making it fit the production K-member with oil level sensor too. Armando only makes sure it fits the block and it is not packaged very well so it comes damaged. Chicane adds the oil level sensor and makes sure it fits the car.
