Any issues with this rim/tire combo?
Sesshomurai
I got a new set of wheels and tires for my track event this weekend and need advice.
It's not the perfect staggered setup, but what I could find on short notice was:
2 Hankook Ventus V12 Evo K110
255/40R19XL 100Y VSB
285/35R19 99Y SBL
Both on RTR 19x9.5 rims.
The only difference from stock is the 9.5 wide rim in the front. Will that cause any problems?
thanks.
There's a guy on SVTP running RTR rims and stock size tires. ALLKHEINZ I think.
Here:
http://www.svtperformance.com/forums/2012-boss-302-mustang-373/869825-my-new-white-2012-boss-302-rtrs.html
Sesshomurai
Yeah, the front tires barely fit, but their snug and the back tires are a bit too wide, but they also fit snugly.
I think after this weekends track day I will move these tires back onto the stock rims and go with a fully square setup on these 19x9.5, with 275x35x19 tires. Does that sound reasonable? Or too wide still?
That would definitely work. Though I'd probably run 285/35 or if running square, but that's just a preference for a taller and wider tire. I definitely think 255 is too narrow for 9.5" rims. I think they're too narrow for the stock 9"!
If you do run square, I'd suggest going to a rear sway bar that's equivalent to about 22mm, or adjustable to that range. JMO.
Sesshomurai
Cool. Thanks Grant!
So I have the 255's on the front now and will be at the track for 2 days starting Monday. I will move to a 275/40 front and 275/35 rear afterwards (for this wheel set), but do you think it's safe with the 255's on the front for now? I realize they will wear poorly stretched on this rim. It was all I could get on short notice.
I don't think there's anything unsafe about the sizes mounted since the manufacturer lists those size rims/tires as compatible. You still need to monitor your hot temps, tread profile temps and wear patterns, etc. to be safe IMO.
