arp wheel stud part number
what are the correct arp wheel stud part numbers your using for the change over.
i have 7703 and 7723 and neither appear there going to work correctly
lol
steve-o
Not sure about those part numbers but the fronts are longer than the rears. Here's the Rehagan Ford Racing versions so maybe you can cross check.
http://rehagenracingproducts.com/product.sc?productId=1792&categoryId=-1
ok,
front looks like a 7722. .55 knurl.
and its like 3.1 long.
1/2 inch.
the rears ill have to pull one of the studs out and chec k its knurl. it might be the same size.
a 7722 arp is correct for the front though. from everything i can see. the 7723 i have comes in a lil bit "large"
3.700 and a knurl of .600 so that would be a good reason for it not to work. its rated for the 2006 aND up moosethangs btw
gremlinsteve said:
ok,
1/2 inch.
Looks like 7722 and 7723
http://www.maximummotorsports.com/store/index.php?main_page=index&cPath=48_135
I've been looking too in case I need to run a spacer up front but really don't want the studs that long. Even with a 5mm spacer up front there would be tons of unused threading
i already have my studs enroute. the ford is just a repackaged arp kit.
shop around and you can get the studs cheaper. by a long ways.
i listed the part numbers so that one may do that now.
